I’ve been lurking around for the past year or so and haven’t had a chance to post (mainly due to crazy work hours). I bought a Misano Red 2015 RS5 in August of 2019 that just rolled 30k miles, and have had nothing short of an awesome experience, up until now.
I’m located in western PA so I was only able to drive it last year until late October, and brought it out of storage in early May. I haven’t had any problems until about a month ago when my coolant thermostat went and I had painfully replace that.
While I was under there with everything removed I decided to change out the rear diff and transmission fluids as the service was upcoming and it’d just make life easier in the long term. Everything felt and ran strong until last week when the CEL came on and put her in limp mode.
I ran the VCDS and came up with a misfire on cylinders 3 and 7. I assumed the best choice was to replace the spark plugs and ordered NGK Ruthenium HX plugs. Replaced them and still came up with a misfire, this time only on 7. I thought that the coil may possibly be shot, but before ordering them I swapped coil 7 with coil 1 and ran the scan again only to come up with cylinder 7 still misfiring. I went ahead an ordered all new coils from HS Tuning.
https://www.hstuning.com/ignition-coil-kit-06E905115G-8-pack-r8-coils.html
I just received the coils about an hour ago and installed them, hence the reason for posting because I have no clue which direction to proceed from here. I ran the scan hoping to resolve the issue, this time with cylinder 7 and 3 misfiring again. Note - I did run the scan with the intake setup still removed.
VCDS readout:
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04—
Coding: 1A25003225A6080D3000
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
ROD: EV_ECM42FSI011_AU48.rod
VCID: 3FDB451C37F1B0C36B9-806A
10 Faults Found:
2638 - Low Pressure Fuel regulation
P310B 00 [096] - Fuel Pressure Outside Specification
Intermittent - Not Confirmed - Tested Since Memory Clear
10541 - Camshaft Adj. Bank 2 Intake
P052C 00 [096] - Cold-Start Timing not Reached
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 60130 km
Date: 2020.10.04
Time: 16:32:10
Engine speed: 3985.00 /min
Normed load value: 78.8 %
Vehicle speed: 50 km/h
Coolant temperature: 98 °C
Intake air temperature: 40 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.253 V
Unlearning counter according OBD: 40
AFS dm: 435.8 kg/h
Median injection timing: 1.960 ms
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
10593 - Cylinder 3
P0303 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 60132 km
Date: 2020.10.04
Time: 16:33:59
Engine speed: 3148.50 /min
Normed load value: 26.7 %
Vehicle speed: 57 km/h
Coolant temperature: 102 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.701 V
Unlearning counter according OBD: 77
AFS dm: 105.0 kg/h
Median injection timing: 0.980 ms
10597 - Cylinder 7
P0307 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 60130 km
Date: 2020.10.04
Time: 16:32:10
AFS dm: 435.8 kg/h
10205 - Cylinder Disabling
P130A 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 60130 km
Date: 2020.10.04
Time: 16:32:18
Engine speed: 3714.50 /min
Normed load value: 33.3 %
Vehicle speed: 66 km/h
Intake air temperature: 38 °C
Voltage terminal 30: 14.465 V
AFS dm: 166.1 kg/h
Median injection timing: 1.278 ms
7656 - Secondary Air Injection System: Bank 2
P0492 00 [096] - Insufficient Flow
7654 - Secondary Air Injection System: Bank 1
P0491 00 [096] - Insufficient Flow
7781 - Engine Off Timer Performance
P150A 00 [032] - -
4201 - Fuel Level too Low
P1250 00 [032] - -
Readiness: 0000 0000
The only other thoughts I have are high pressure fuel pump, low pressure fuel pump, injectors, or a carbon clean.
You guys on this forum are incredible and have lead me to such a wealth of knowledge trying to understand this beast.
Ape, you’re my hero because without you I wouldn’t have been able to do all of the maintenance and problem solving up to this point without your vast amount of postings.
I’m at a loss with how to proceed as of now and any insight is greatly appreciated.
- Luke
). Look around the engine and where it has been worked on recently. Low voltage can indicate either of the two. It would, however, more likely throw faults on the electronic park brakes, TPMS, ESP if it was voltage/a connector.
