2g to 3g MMI
While the car is getting worked on I’ve been trying to come up with another project to update the car so i dont go and buy a new one.
Looks like its possible to retrofit the 3g mmi… I’ve also seen people retrofitting 3g+ so i think this is the next project.
http://www.audi-sport.net/xf/threads/my-a6-3-0tdi-avant-bit-of-a-rebuild-and-repair-thread.211351/page-2#post-2182122
Good idea. let us know how this all goes as I may want it done later too.
Check this…
http://www.ebay.es/itm/Navegador-Audi-MMI-2G-high-7-A4-A5-A6-A8-Q7-WinCE-GPS-Multimedia-BT-/221772645892
Can’t speak spanish - what is it?
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/MrgAAOSwa-dWtc71/$_12.JPG
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/LScAAOSwa-dWtc7A/$_12.JPG
Description:
NaviTouch® WinCE 6.0
Complete and integrated system, touch navigation, multimedia and bluetooth (optional)
Compatibility:
Audi A4, S4, RS4 (8K) 2007-2009
Audi A5, S5, RS5 (8T) also Cabrio. 2007-2009
Audi A6, S6, RS6 (4F) 2004-2009
Audi A8, S8 (4E) 2004-2009
Audi Q7 (4L) 2004-2009
Requirements:
MMI 2G High with a 7" color display.
Main features:
With NaviTouch® WinCE you can give up using portable GPS devices inside of your vehicle, with visible wiring harness and other objects that affect visibility and security while driving. It will also let you maintain your vehicle’s interior factory look.
NaviTouch® WinCE is a complete and integrated system which delivers GPS touch navigation, Bluetooth handsfree and multimedia to Audi vehicles that include a MMI 2G High system and a 7’’ color display.
Full integration in your vehicle!
Fully integrated touch system for Audi vehicles; using the 7" factory’s color display.
Interact by touching the anti reflective touch panel!
You can control the navigation and other functions by touching the antireflective plastic touch panel located over your vehicle’s original display. Now you can also adquire the new glass type touch panel, which improves the visualitzation of your vehicle’s screen.
3D Navigation!
Enjoy the most advanced 3D navigation software in the market in a fully integrated way on your vehicle, with Europe or other continents navigation maps. In addition, you also can install other manufacturers navigation software, like: TomTom, Sygic, Automapa etc…
Bluetooth phone system with your address book! And with a hidden microphone!
Now you will be able to connect your phone by bluetooth tecnology, make and recieve calls, and in addition, you could also browse your address book contacts and the call register (lost calls, recieved, sent). And also it includes a hidden microphone to be placed in the overhead courtesy lights panel. *Note: It will be necessary to comment if vehicle includes a factory bluetooth handsfree system.
USB connection port!
Using the USB connection port, you will be able to play your favourite audio, video and image files (compatibility with devices up to 16GB).
Capable to read most of the audio file formats: MP3, PCM, WMA…!
Play your favourite audio files: mp3, pcm, wma… By an easy and comfortable way, through the NaviTouch’s® intuitive touch interface.
Capable to read most of the video file formats: mpeg, mpg, dvix, avi…!
Play your favourite video files: mpeg, mpg, dvix, avi… By an easy and comfortable way, through the NaviTouch’s® intuitive touch interface.
It gives to you navigation indications through the speakers of your vehicle!
The voice navigation indications are reproduced through the original front speakers of the vehicle like in the original sound system of the vehicle, by reducing the audio volume which is played at the moment of the voice indications emission. It is also compatible with Audi sound system vehicles (9VD-9VE).
Connectivity with multimedia devices!
Now with the NaviTouch® system you could connect various multimedia devices like dvd players, dbt tunners, rear camera systems… etc (up to 3x AV inputs)
A huge range of languages to select!
Now NaviTouch® ofers a new user interface with a lot of languages such as: English, Chinese, Deutsch, Français, Spanish, Dutch, Magyar, Česky, Dansk, Norsk, Svenska, Portuguese, Italian, Finnish, Romanian, Russian, Polish.
Compatible with Windows CE 6.0!
http://www.vagnavisystems.com/cib/js/lib/tiny_mce/plugins/imagemanager/files/Interfaces_Multimedia_nova_w/4G1919612S_mmipanel_.jpg
If you want to upgrade or change your navigation software, NaviTouch® is compatible with Windows CE 6.0; the most used OS in the market. Get and use any navigation software which runs under Windows CE 6.0 and play it in your NaviTouch®.
It is an exclusive system in the market, because it incorporates reminders of the navigation through the speakers of the vehicle, Bluetooth connection with a hidden microphone, friendly user interface with a nice graphics, new anti reflective touch screen and a huge range of languages to select.
In addition, NaviTouch® can be controlled through vehicle’s CAN-BUS, and it is compatible with the new Audi models with MMI 2G. You’ll be able to switch between Navigation mode and original (OEM) mode through the MMI’s panel “NAV” button, and also will be able to enable one of the 3x AV inputs that product offers.
You could also install an aftermarket integrated rear view camera (optional), with camera’s image signal autoswitch when engaging rear gear of the vehicle
Package Contents:
WinCE 6.0 GPS module
Processor: 900 Mhz
Operative system: WinCE 6.0
RAM memory: 200Mb
Specific video inserter interface
Power wiring harness, includes the following connectors:
CAN BUS
Switch button
LVDS monitor cable connection
3x video inputs
Rear view camera input
GPS antenna
6.5" touch panel
Hidden microphone
1x 2m USB connection extensor
1x 46cm SD card connection extensor
1x Stylus
Voice module + Plug & Play adapter wiring harness
Notes:
Before make an order, it’s necessary to send us an email with your vehicle’s chassis VIN number. Our team will check the sound system and the equipment installed. You can send the chassis number to info@vag-navisystems.com
We recommend that the installation will be performed by a qualified specialist
Bluetooth optional
Audio integration:
The audio from this system, will be played through the original (front or front+rear) speakers of the vehicle, by reducing the audio volume which is played at the moment of the audio emission. Very useful for using with a navigation software. It can be connected also to the AUX input.
another model
https://www.youtube.com/watch?v=q8VIuIliu-4
mmi 4g to 4f ?
http://i1128.photobucket.com/albums/m498/thilojena/65B1E84D-F620-4AEC-BAFB-506CD34C4BD4-3193-00000C6D4BFE0EEA.jpg
http://i1128.photobucket.com/albums/m498/thilojena/D11EE129-F186-4B67-AE9A-27653E80E04E-3193-00000C6D410D61F5.jpg
http://i1128.photobucket.com/albums/m498/thilojena/19461288-91C9-4CA4-8A1E-298126EAFFFF-3193-00000C6D46CDAD3A.jpg
http://i1128.photobucket.com/albums/m498/thilojena/D489D4F1-A261-4B23-BB8B-D2D44EE8B65D-3193-00000C6D5235ADFA.jpg
http://i1128.photobucket.com/albums/m498/thilojena/D62C3415-AD64-4C12-9DE4-7FBB8C1EB300-3193-00000C6D5A64D87E.jpg
http://i1128.photobucket.com/albums/m498/thilojena/E40F6C10-E6DF-4F4E-BAA1-7F29E24EC4EE-3193-00000C6D32058924.jpg
https://scontent-amt2-1.xx.fbcdn.net/v/t1.0-9/10696441_912102628818371_7423452891887589120_n.jpg?oh=2bae6a113b2a0fca05be4f26918a852a&oe=59194F18
https://scontent-amt2-1.xx.fbcdn.net/v/t1.0-9/10689619_912102698818364_561820944671619489_n.jpg?oh=36826c362d8fe082a591bd9c673d52cf&oe=58DDCD1E
daaaammmm that black dash looks great! More info on 4f(?) please!
Super clean swap. The center console seems like it’d be the hardest thing to change, but still nice to keep in mind if I ever hit the lottery lol
