took this video today…sorry for the quality
http://www.youtube.com/watch?v=OtaegwvaVTo
Explain why you would do a 50-120 pull at 75% throttle, take a video of it, and post it? DO you have logs to prove that your throttle position was at exactly 75% for the entire pull?
…what is the purpose of this?
Nice to have you post but I do agree, what’s the point of saying you only went 75%? This isn’t meant to be an attack on what you did but more of an attempt to understand what you were looking to show.
Unless you down shifted on your own the car won’t down shift at that RPM in that gear unless you’re WOT. I suppose you could have something in the GIAC Tip program that would do that
a few people mention that i am going to see significant improvement with JHM tune installed.
so took the video to show overall performance of the car as is.
In addition there are no videos showing GIAC tip chip in work. So for some people i thought it might be interesting.
That is understandable, but your video says 50-120 km/h at 75% throttle. There is no way you knew you were at 75%, not to mention no one is going to go out and try to replicate a 75% throttle run to compare their car.
I would recommend doing a 100% throttle pull (which I think that you did and for some reason you called it 75%) or trying to get some drag strip passes in when the weather warms up. Then after the JHM tune you will be able to assess you gains easier.
…and now you deleted your 75% throttle comment from your description???
euroswagr,
thanks for your comments and i will probably do 0-100 video soon.
i dont have an actual screenshot of the throttle position at the moment…
however when i say its was 75 it 75…at least this is what i had on my full android deck running torque pro
thanks for the tips…will be more accurate next time;)
Do 0-100km and then video again after you’re JHM tuned. Then you can overlay the video and see the difference, I did that and I think I uploaded a video of it on here, pretty cool.
Lol ever race anyone at 75% throttle?
"OK GO ON THE THIRD HONK FROM 50… AND LETS TRY THIS ONE AT 45% THROTTLE!! "
Haha, ya I wasn’t trying to be a dick…I just don’t see the point to post data that is impossible to replicate for other members to use.
The gas pedal is a load request pedal. So even if you have it 75% the way down, that doesn’t mean the TB is 75% open. The ECU will aim for 75% load which may mean 60% throttle of maybe even 85%. You have no way of knowing.
