3G+ MMI - Tethering Data from a mobile and WAP activation
Hi All,
Attempting to run the sd scripts on an “A3 8V 2014” model and it fails to run. I have the sat nav 7inch mmi package on the car.
I see “Update medium” on the mmi console for the sd card but nothing else happens. Any tips to get the scripts to run so the dns can be updated and the green screen activated?
Thank-you
Would this work on MMI 3G? Not the plus model.
Went into the green menu and enabled the WLAN; I can now connect my iPhone to the car’s build in WLAN…
Cheers,
Shaun
Hi all. Just got a 2015 Q7 and was wondering if there was any new updates or shortcuts. Would love to get wifi from the phone to the car and the original post of almost a year old. Thanks.
I noticed that you wrote “MMI 3G”. Will your solution work with 3G, or only 3G Plus? I have a 2012 (early, pre-facelift) Audi S5 Cabrio that I received here in Canada, in August 2011. It is MMI 3G I believe.
Thank you!
Hi Shaun,
Nobody answered you here. Did you ever get the answer to this question? I have the same one.
Please let me know.
Thank you,
David
Im using 4G usb modem connected to the tplink instead of WISP, and it works with my phones and computer but not the car?
Could that be the problem?
i connected the Dlink rj45 usb converter to the computer and it works there…
but one thing is different.
when i connect it to the car, one led light on the dlink shows orange and the other green.
but on the computer both starts to shine green.
it seems like the config file is wrong. ive had some problems installing it…
as far as i know ive put everything on the root of a memory card, changed the config file ip number to 192.168.0.1 as the router has it. saved it then connected it to the car, shouldnt the script start by it self?
beacuse it does not to that on me…
even when i go to MMI Setup then software update and chose the SD1 or 2 where i connect it, it gives me an error saying that the sd card is not avaliable or something.
could someone send me another rar file with everyhting in it, with the ip number 192.168.0.1?
maybe somehting went wrong when i edited the file.
I have the latest Europe version firmware and 2015-2016 maps
http://uploads.tapatalk-cdn.com/20160219/721695b99110d2df4caa7d3ed3e7cfaa.jpg
The activation menu is gray and cannot click on it.
http://uploads.tapatalk-cdn.com/20160219/9dbdf2ce8e82edd70f221e0ffae2cb71.jpg
When i change settings to google and start navigation, it takes time
http://uploads.tapatalk-cdn.com/20160219/6cd306156576986061af148839948f66.jpg
Then i get this error, also i cannot use audi vonnect, althought i can connect to it from my phone… Strange and i cant get any live tmc messages via audi online from the navi
http://uploads.tapatalk-cdn.com/20160219/e9b8369e32614e37e14edd4a1fa3c81e.jpg
What am i doing wrong???
http://uploads.tapatalk-cdn.com/20160220/2cb3f3b8b77b44829b3a325ee91e2952.jpg
http://uploads.tapatalk-cdn.com/20160220/0757b5f8d6548a6668839958d240122f.jpg
http://uploads.tapatalk-cdn.com/20160220/93c2916be07863d30aa5fa052cd3eb68.jpg
http://uploads.tapatalk-cdn.com/20160220/7327af8b80a1c34eb72c5d16335a2468.jpg
http://uploads.tapatalk-cdn.com/20160220/803070b5616c84b1d6ed2f6975201b7c.jpg
http://uploads.tapatalk-cdn.com/20160220/654e259f0b632771f7f29283ee075dd9.jpg
http://uploads.tapatalk-cdn.com/20160220/6bc184cad2bcf515f9472db7cccb0f3d.jpg
http://uploads.tapatalk-cdn.com/20160220/59c17227df66b248c6f85fc3b2b094fb.jpg
http://uploads.tapatalk-cdn.com/20160220/e091e35400d53001157a61c7d4c65c8e.jpg
http://uploads.tapatalk-cdn.com/20160220/9d261667ae0e42f2b743ff7423c93013.jpg
http://uploads.tapatalk-cdn.com/20160220/51d62a6ed3dfcf0c9f2335910226aff0.jpg
http://uploads.tapatalk-cdn.com/20160220/b5f035d585b1890ae96d1a070fed7cda.jpg
http://uploads.tapatalk-cdn.com/20160220/c8d00841a35b253a578022e06ff638a5.jpg
Hello,
I read that after update K770 there is possibiltiy to use data from SIM card or via bluetooth in rsap mode (there is an android application that give support for rsap, but i think you can not connect with iphone).
I have audi a7 without sim slot and I enebeled NAD option and NAD operation in green menu (I am curretly on K783). Now I have possblity in my bluetooth setting to connect to handsfree, audio player and car phone (this is rsap funciton). But my phone does not want to connect with car phone, other functions are working without problem.
My question is if I need to do some aditional coding with vcds or enable some other funciton in green menu or my car simply miss some hardware?
If I could connect to my phone via car phone option, then I would be able to use online services directly via my phone and I would not need an extra router and this workaround.
And another tweak that I found over internet and have not been posted here:
This is how you can enable online traffic (I do not know if this will work, because you need to activate this via MMI info>Setting menu and I read that you get 1 year free subscription, but I did not try this yet only activate menu (I did not eneble data transfer yet)).
[Select]
[5F - Information Electr.]
[Adaptation - 10]
Select Channel 69 and Read
change the value from 8 to 32768 then Test then Save
Reboot the MMI (Press MENU, central MMI knob and top right softkey)
Then when you go into the list of sources in INFO>SETTINGS, you will now have the additional items of “Online Traffic Data” and “Online Traffic Data License”.
I have successfully tethered my iPhone to a TP-Link router and TrendNet adapter via the USB AUX cable.
Issue –
Google Earth will not load. The “Goo” in Google will turn white, but “gle” remains greyed out. Google Earth is also greyed out in the Nav menu although I can select it.
I have let the car sit in an area that I know has coverage and the map would previously load using the SIM card for 20-30 minutes and it only loads the “Goo”. If I go into googleearth in the green menu and choose Start Service, I get a message that’s it’s already started, but when I back out to the Nav, Google Earth is no longer greyed out and the logo loads fully, but it sits at the “Please wait…” screen and never presents the map. I can hit the back button and it will display “Google earth is loading data do you want to view the standard map?” I can also choose Restart Service with the same results. I have tried clearing the cache, deactivating and reactivating the service, but to no avail. Once I restart the MMI after tinkering in the green menu, it only loads “Goo” and is greyed out in the Nav menu.
All of the following services are working as they should:
Audi Connect – able to pull weather and news
Traffic – TMC is active
Google Search – able to lookup online destinations and related details
Wi-Fi Hotspot – able to connect to the car hotspot and surf the web
iPhone MMI Connect App – able to play internet radio stations and load music library
Quick Details –
Car – 2013 B8.5 Post-Facelift Audi S4 (FL) APR Stage II+ with TCU Upgrade
Software Version – HN+_US_AU3G_K0942_3
Navigation database version: 8R0060884AM NAR 5.6.5
Green Menu Version – <EM 1.0t>
Green Menu Settings –
/diagnose/coding/internal_modules_1+2 –
SDS (Off): Disabled
NAVI (Off): Disabled
PSD (Off): Enabled
VZA (Off): Disabled
ECALL (Off): Enabled
Online POI (Off): Disabled
Online Portal (Off): Disabled
Offroad Navigation (Off): Disabled
Online POI voice (Off): Disabled
/diagnose/settings/tel_settings –
Delay reference signal (ms): 0
Mic sensibility: [0 db] 2/3
HFP activation: Enabled
BT activation: Enabled
NAD activation: Enabled
NAD operation mode: Enabled
HFP activation type: Disabled
BT default visibility: [auto] 1/3
/diagnose/settings/ami_aux –
AMI: [enabled] 1/2
AMI BT: [enabled] 1/2
AUX: [disabled] ½
/diagnose/settings/wlan_settings –
WLAN activiation: Enabled
Max channel number: 11
/config/Console –
[INFO] /etc/resolv.conf: nameserver 192.168.0.1 nameserver 134.60.1.111
Routing table: Destination – default, Gateway – 192.168.0.1, Flags – UG
/googleearth/Console –
GEMMI 8.0.2.5
Embeddedearth 5.2.0.6394
AROMA 2.1.4 (20110707)
libhydragoogle 5.0.3
I am so close here. Is there a way via VCDS to reinitiate Google Earth or am I missing something in my setup above? Any advice would be greatly appreciated. I am super frustrated since everything else is working so well. Thanks in advance for any advice you can provide.
The link for dns.zip is not workking anymore.
Can you help me?
Thanks
I realize this is a very old thread, but with the demise of the 3g networks in North America, I think the issue is pretty current.
I would love to try and implement this in my 2013 A8L, but the links are now inoperable. Does anyone have the information saved somewhere and is willing to share it?
I would like to figure it out and share with everyone here how it goes with my car.
Thank you!
Hi everyone,
I know this thread has been quiet for a while, but I’m revisiting this project and would love some input. I’m trying to set up Wi-Fi tethering on my 2016 Audi A8 with the 3G+ MMI system. Since the 3G network shutdown, I’ve been looking for ways to reconnect the car to online services, and this method of using my phone’s hotspot seems like a great solution.
However, some of the links (especially the script downloads) appear to be broken or no longer available. If anyone still has access to the necessary files or updated resources, I’d really appreciate it if you could share them or point me in the right direction.
Also, if anyone has tried this on a similar model or has tips for configuring it on a 2016 A8, I’d love to hear about your experience!
Looking forward to your feedback and hoping to get this working.
Thanks in advance!
