3rd gear pull???
Would it be possible for someone with a carbon free car do a pull video in 3rd gear for me? from like 2k-8k. I would like to see how my car stacks up, because as of now its feeling a bit sluggish… Cheers!
Presume you mean an RS4? Try a throttle adaptation reset as well, that always wakes my car up.
If you have VAGCOM: http://www.ross-tech.com/vag-com/cars/throttlebody.html
If you don’t: http://www.audizine.com/forum/showthread.php/16531-B6-A4-Easter-Eggs!-Features-not-found-in-the-owner-s-manual?p=193681&viewfull=1#post193681
[quote]Manual throttle body adaptation:
"The Throttle is “Drive By Wire” and adapts to your particular driving style. Do a TBA Throttle body adaption).
  1. Get in your car, it doesn’t matter if you close the door or not.
  2. Turn the key to the on position, the position just before the starter turns over.
  3. Press the gas pedal to the floor with the key in the “on” position.
  4. Hold the pedal to the floor for five seconds, then turn the key back to the “off” position(don’t remove the key), then release the gas pedal.
  5. Wait 2 mins. for a full alignment. During this time you may hear very faint noises and clicks. I
    only heard one sitting in my car, if I got out and popped the hood I might hear more.
  6. Drive the car as you always do.
Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
I noticed a big change after erasing my history. It is not hard to do this, just follow the
instructions - Key on, pedal down, 5 sec, key off pedal up, wait 2 minutes.
Keep the key in for the entire thing. "
Having said that I’m not 100% sure if either method is the same for the dual ECU RS4.
Yeah, 07 rs4… I’m an idiot for not mentioning that… thanks for the reply, I will give those a shot see if they work .
where are you located?
do you have vagcom?
do you have a pbox?
I have a carbon-full RS4 (I assume…30,000 miles and never cleaned) but it runs as fast as any stock RS4 I’ve ever seen. I can give you whatever you want really. Vid of the speedo…logs…pbox data…whatevs.
Saki I am in CT, 45 mins out from NYC. I do not have a vagcom cable but i ordered this… http://www.amazon.com/gp/product/B002WIN8VQ/ref=oh_o00_s00_i00_details not sure if it will even work witht the ross tech software… As far as pbox I am working on that, ebay has some for sale now that I am bidding on.
Where in CT? I am in CT and can log your car if you would like.
Fairfield County. New Canaan area.
