So I had my 2010 4.2 V8 RS5 delivered to me a few months back and wanted to make others aware of how I sorted out a massive issue that got so bad it was undrivable.
She was running rough and revs were all over the place…having had it just delivered I was not a happy customer. It was showing the following faults… Sport differential: System fault, Tyre pressure: System malfunction, Parking brake: malfunction, Stabilisation programme fault: See owners manual
So how did I fix this issue? The 4.2 V8 has 2 x Throttle Bodies and a connector on each…each connector having 6 x wires. I’m pretty sure that the issue was with just the right throttle body but I wanted to make sure this didn’t happen again so I sorted out both sites of wires.
So…when the V8 gets hot (or even randomly) the resistance of these wires going into the connectors changes and the engine tries to compensate.
All that was needed was 12 x wires in total (6 x wires for each connector - £112 in total!!) Remove the terminals from the connector that attaches to the throttle body, cut and solder in the replacement wires and insert into connector…Install to throttle body and repeat for second throttle body.
Cleared faults and everything has been fine ever since.
I hope that someone may find this helpful as this as I had no idea what was going on and the faults showing on the dash made me think it was a major issue.
Drive safe guys
