4.2V8 BHF - Component location diagrams and vacuum line diagrams
A few people were asking for this on Audizine
Here are the common vacuum connections in engine bay: Look at the Black Arrows for connections
http://i48.photobucket.com/albums/f202/sewermonsterBW/A10-1525_zpsvcf8co9y.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A10-1875_zpsbupzvuit.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A10-1458_zpsadjzbxaa.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A15-0873_zpsvvebxdkn.gif
#4 in this image
http://i48.photobucket.com/albums/f202/sewermonsterBW/A15-0865_zpsobzpgbfu.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A10-1523_zpsj3d4hl1i.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0828_zpsuys7tzgq.gif
1 - Evaporative Emission (EVAP) canister purge regulator valve N80
2 - Mass Air Flow (MAF) sensor G70 with Intake Air Temperature (IAT) sensor G42
3 - Connector console
Pin assignment
Assignment of holder for connectors (right side)
4 - Valve 1 for camshaft adjustment N205
Rear view
5 - Camshaft Position (CMP) sensor G40
Cylinder bank 1
Rear view
6 - Engine coolant temperature (ECT) sensor G62
At coolant pipe behind cylinder head, bank 1
Rear view
7 - Fuel supply line
8 - Throttle valve control module J338
With Throttle drive (power accelerator actuation) G186 , Angle sensor -1- for throttle drive (power accelerator actuation) G187 and Angle sensor -2- for throttle drive (power accelerator actuation) G188
Rear view
9 - Oil pressure switch F1
Rear view
10 - Camshaft Position (CMP) Sensor 2 G163
Cylinder bank 2
Rear view
11 - Connector console
Pin assignment
Connector console beneath coolant expansion tank
12 - Valve -2- for camshaft adjustment N208
Rear view
13 - Engine Speed (RPM) Sensor G28
In transmission housing above ring gear
14 - Ignition coils with output stages
Cylinder bank 2
15 - 3-pin connector
For Knock sensor 3 G198
For Knock sensor 4 G199
Front view
16 - Secondary Air Injection (AIR) Solenoid Valve N112
Front view
17 - Intake Manifold Change-Over Valve N156
Front view
18 - 3-pin connector
For Knock Sensor (KS) 1 G61
For Knock Sensor (KS) 2 G66
Front view
19 - Ignition coils with output stages
Cylinder bank 1
20 - Secondary Air Injection (AIR) Pump Motor V101
http://i48.photobucket.com/albums/f202/sewermonsterBW/A20-0801_zpsqycqo1t4.gif
Installation location of Fuel Pump (FP) Relay J17
Position - arrow 1 - on 9-position relay carrier on left of drivers footwell.
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0430_zpsnx3itvjt.gif
1.1 - Coolant Circulation Pump Relay J151 (hot countries only)
1.2 -Not used
2 -Secondary Air Injection (AIR) Pump Relay J299
3 -Motronic Engine Control Module (ECM) Power Supply Relay J271
4 -Relay for automatic transmission
A -Engine electronics fuse S282
B -Secondary air pump fuse S130
C -Not used
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0734_zpsxx2dutgx.gif
  1. 6-pin connector for Heated Oxygen Sensor (HO2S) G39 and Oxygen Sensor (O2S) Heater Z19 before catalytic converter, bank 1
  2. Connector for starter (terminal 50) and generator
  3. 2-pin connector for camshaft timing control, bank 1
  4. 4-pin connector for Oxygen Sensor (O2S) Behind Three Way Catalytic Converter (TWC) G130 and Oxygen Sensor (O2S) Heater 1 (behind Three Way Catalytic Converter (TWC)) Z29 , bank 1
Intake Manifold front
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0680_zps1kiuax1y.gif
1 Vacuum unit for intake manifold changeover
2 Knock Sensor (KS) 1 G61
3 Knock Sensor (KS) 2 G66
4 Intake Manifold Change-Over Valve V156
5 Secondary Air Injection (AIR) Solenoid Valve N112
6 Knock sensor 3 G198
7 Knock sensor 4 G199
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0681_zpsfuoy7xks.gif
  1. Valve -2- for camshaft adjustment N208
  2. Camshaft Position (CMP) Sensor 2 G163 , cylinder bank 2
  3. Oil pressure switch F1
  4. Throttle valve control module J338
  5. Engine coolant temperature (ECT) sensor G62
  6. Camshaft Position (CMP) sensor G40 , cylinder bank 1
  7. Valve 1 for camshaft adjustment N205
http://i48.photobucket.com/albums/f202/sewermonsterBW/A26-0670_zpsrz7d5u32.gif
http://i48.photobucket.com/albums/f202/sewermonsterBW/A24-0123_zpsufpuizwb.gif
Leak detection pump (LDP) V144
