Hey guys, ive owned my R since November but have only recently begun to modify it. My intentions were to keep it stock and enjoy the car as a solid daily but a track visit a month ago yielding better than expected results made me put my personal touches onto this car.
First run with the car bone stock got me into the 13s which surprised me. At that point I figured I had a strong running car and could really build upon this.
http://i37.photobucket.com/albums/e52/91gl/20140323_134302_zpsc0eb92f3.jpg
First things first, I did a simple dog bone mount insert from ECS to help with shifting and drivetrain movement on launch. Lightweight components were next. I had an ETS 10lb Lightweight Battery Kit from a friends Evo VIII that he never used and mounted it in the rear. Stock battery is over 50lbs and the difference was immediately felt. So the lightweight theme continued…next up was a Bride Zeta III seat to remove the heavy driver seat.
http://i37.photobucket.com/albums/e52/91gl/20140410_185337_zps2e56e9ae.jpg
Knowing i was planning on running nitrous and a large shot, I had to free up the exhaust. USP Motorsports catless downpipes were modified to merge into a single 3.5" aluminum catback that turns down right before the rear diff. System is featherlight compared to the stock system. Gained plenty up top which was fine with me especially with the nitrous i was planning on running.
Lightweight wheels were next along with ECS lightweight brake rotors but 17x9 et45 Enkei RPF1’s just would not clear my stock brakes so I had to go smaller. Was planning on downsizing to GTI brakes but they do not offer lightweight rotors for the GTI’s at a reasonable price so I had to get drastic. Picked up a set of Wilwood Racelight 6 Piston 327mm front brakes. This made a drastic difference and are about half the weight of the stock two piston setup which is similar to stock b6/7 s4 brakes.
http://i37.photobucket.com/albums/e52/91gl/20140425_224339_zps410c6fa5.jpg
http://i37.photobucket.com/albums/e52/91gl/20140428_085313_zps52fb5f3e.jpg
http://i37.photobucket.com/albums/e52/91gl/20140428_085321_zps27e12747.jpg
http://i37.photobucket.com/albums/e52/91gl/20140428_085331_zps35fbb4cf.jpg
Yesterday was Spring Show and Go at Englishtown and with the nitrous dialed in perfectly at 100 shot, I was able to get 11 passes in with the car running absolutely flawless. Setup is stock ecu/dsg tune with NGK DCPR8E plugs gapped to .030 on pump gas. AFE Intake with a single fogger nozzle tapped into it. Nitrous pill is .052 and fuel is at .030.
Best time from yesterday:
http://i37.photobucket.com/albums/e52/91gl/20140427_141218_zps4dbef3ca.jpg
Going to push the stock setup/single nozzle as far as I can go before doing a short runner/direct port setup along with a built motor. Next though is working with JHM regarding a tune for engine/dsg, Fluidampr crank pulley, lightweight rear rotors, some carbon parts and so on to decrease weight. My goal is a 10 sec 1/4 by the end of the year and also go deep into the 11s by Waterfest.
