93 Octane (or better) in Kansas City?
The last time I was there I could only find 91. I’m going there for the Art Museum Concours this weekend. Does anyone know where I can find the good stuff for my 93 octane JHM tune?
Thanks
Do you have VAG-COM? When you fill with 91, just use it to reset the ECM and the car will adapt to the 91.
Or, just take it easy. Stay away from WOT and you won’t have an issues.
Or, get some Lucas octane boost. I think 1 bottle will get you up to 93 from 91
Yes, Reset the ECU and you should be ok. The ECU will adapt even with 91, it’s just best to be careful. You can disconnect the battery terminals to reset as well.
Thanks all. I appreciate the info, but I found a BP station that has 93.
Furthermore, I got over 26 MPG on the way back to STL. Maybe I should reconsider BP vs Shell.
