The left portion of the left center dash outlet blows cold but the right portion is chilly but not cold. I’m wondering if it has to do with the blend door. Is there a way to check this with VCDS?
That would be a blender door issue. Yes you can run an output test in VCDS. It’s obviously in the HVAC section. You can trigger all of the system.
