All items listed are brand new in box. Not used, not installed, not messed with but from a dealer (me) being offered as new and with any warranties in place. Items were set aside for a build and plans changed. Prices reflect wholesale. If you are a real buyer looking to make an offer, please do so.
1 - Ohlins Suspension system by Stasis $3199
http://www.stasisengineering.com/products/suspension/suspension-a4s4-motorsports with 800/1000 springs. This system was hand built in 2007 by Ford Cook, back in the race days so it is legit. Can be updated to swivel banjos by PSI for $100
1 - Guard LSD for rear differential, 951 pro unit modified to fit our diff housings $2000
http://www.guardtransmission.com/products/limited-slip-differentials/
Direct fit, true LSD. I have run one of these and a spool, the LSD is great for road course and daily driving, spool is great for drift and drag.
1 - Cook O1E Race 6 speed transmission $4900, hand selected and finished by Ford Cook. All new parts cryogenically treated, heat treated where applicable, REM polished, two center diffs included, 4:1 installed and locked spare, open front diff, street gear ratio set (longer 1 & 6), ported oil passages and fitted for cooler.
1 - Alcon 328mm Mono6 front brake kit $2550
http://www.stasisengineering.com/products/brakes/brakes-328-mm-mono6-a4s4rs4
pre-2009 caliper castings and rotor metallurgy (better). Silver.
1 - Custom Tial 770r turbo set $4800
http://www.tialsport.com/prod_turbosystem.html
These are not normal 770s, these have Alpha Comp covers or “Cosworth” covers as most call them, the compressor cover can flow more and the turbo cannot bolt to stock manifolds. They are geared around custom manifolds. The kit includes the turbos and oil/water plumbing, thats it. They are good for more power than standard 770s. Manifolds/downpipes/inlets are also available for these, only if also purchasing the turbos for $4500
1 - SDR Carbon Fiber Y-pipe $450
http://www.sdr-research.com/ypipe/ypipe.htm
SDR doesnt make these anymore, hard to find.
1 - Evolution Racewerks Intercooler kit $1180
http://www.evolutionracewerks.com/node/61
All the cool kids have them
1 - H-sport Sway Bar kit $500
http://www.hotchkis.net/audi_b5_sport_sway_bar_set.html
see above
1 - OEM Carbon Fiber interior trim set $800, from a B5 RS4
not some overlay…
