http://img521.imageshack.us/img521/5158/nineyfoessfo.jpg
What does one drive when the B6’s ECU is out and on the way to California? A 1994 S4. Which is really an S6 generation 1.
I bought this because I want to learn to wrench on cars as a pastime. However, my B6 is soon to truly become a family wagon so downtime isn’t an option, plus it doesn’t seem to be the easiest to work on with the V8 crammed in there. I also wanted to have a “winter beater”. My current commute to work is short so my B6 never really warms up, the implications of this being (1) more wear and tear on the precious V8 and (2) I rarely get to beat on the car even though I really want to.
So in steps “Bruce” the green monster and I am beating the arse off it around town. Considering there are 400,000 km on the body and 220,000 km on the engine, he’s in pretty good shape. The PO did a cut n weld job on the downpipes so I’m catless. Other than that it looks stock (although I thought that about my B6).
My goals are to DIY as much as possible on the car. I had to have some $$$ spent on the safety inspection as I wasn’t ready to do control arms yet and wanted to get it on the road ASAP. The list:
- Done: installed a sound system (bits and pieces off Kijiji), some rewiring of the hack job behind the radio, which also got my climate control working
- Near future: Get all the maintenance type stuff done like oil, spark plugs, fuel filter, brake pads, fix e-brake, sort out wandering idle. Get him running nicely before the other stuff
- Over the summer: Some sort of Holset turbo (HY/HX35), exhaust mani, exhaust (with cat), injectors and other supporting mods including tune (does the Count tune I5’s?!)
- Maybe, just maybe in the dim and distant future (or sooner if the compression test is not good): Engine pull and light build (as I understand it, rods are the main weak point)
Goal: fun daily on the cheap, learn to mod cars.
If I get really serious and into this, then I’ll go full retard restoration and come up with a build to get me in to the 12’s. That’s why I chose this car - there’s a lot of potential in the AAN 20vt 5 cylinder. I will eventually start a build thread on motorgeek.com but I thought I’d share here first in case anyone was worried I was having to walk everywhere while I get my ECU JHM’d
