A8/S8 D3 label files
Some of you may have noticed the lack of label files for engine and level control on these cars so I made some to make testing the engine and level control easier.
Just unzip the linked file in to your label folder in the VCDS directory.
The info should be good unless i have messed up something, the info came from here http://www.audi-portal.com/en/diagnostic/ecu_10542.html#1 but it also matches what VAS-PC says.
https://drive.google.com/file/d/0B1XtiHd0Y9MTcnFEcnA3RkhYUGs/view?usp=sharing
Deloy welcome to the site. There is a good mix of S8 and S6 guys on here. most of them meet on the S6 side but its good to make sure everyone loads the S8 side as well.
For you tag list is this the stuff you fillied in
Display groups for 4.0 L TDI CR as at 22.01. 2008
001 Quantity adjustment
  1. Engine speed
At idle: 672 rpm (specified)
  At full throttle: 3000 rpm
  1. Injection quantity
At idle: 4 … 15 mg/stroke
  At full throttle: approx. 57 mg/stroke
  1. Rail pressure actual
    Check values with measured value block 022
  2. Coolant temperature
Warmed-up: 70 … 110 °C
002 Idling speed
  1. Engine speed
    [rpm]
  2. Accelerator pedal position
3)Switch settings
  - X - X X - - 1  AC compressor ON
  - X - X 1 - - X  Idling speed switch ON
  - X - 1 X - - X  Kickdown switch ON
  - 1 - X X - - X  Idling speed increased
  1. Coolant temperature
003 Exhaust gas recirculation
  1. Engine speed
  2. Specified exhaust gas recirculation
At idle: 310 … 320 mg/stroke
  1. Air mass bank 1
At idle: 305…320 mg/stroke
  1. Air mass bank 2
004 Main injection
  1. Engine speed
  1. Main injection, start of activation
    At idle: 1,5 … 1,9 °CA
       At full throttle: 14,5 ... 15.0 °CA
  2. Main injection, duration of activation
    At idle: 0,5 … 1,0 ms
       At full throttle: 1055 ... 1065 ms
  3. Rail pressure actual
005 Starting conditions
Stored from last engine start
  1. Engine speed
    [rpm]
  2. Starting injection quantity
    10…25 mg/stroke
  3. Start synchronisation
    000 Basic initialisation
    001 Reset counter
    002 Engine standstill or fault
    003 Transitional states
    004 Plausibility check phase
    005 Plausibility check phase
    006 Plausibility check phase
    008 Plausibility check phase
    016 Phase definition
    028 Redundant start
    032 Synchronisation phase
    033 System positioning
    048 Calculation sequences activated
       --> Starting OK
    064 System waiting for engine standstill
    128 Dynamic plausibility check
  4. Coolant temperature
    [°C]
006 Cruise control system CCS
  1. Vehicle speed
       CCS activatable: above 35 km/h
  2. CCS status
    X X X X X X X 1 Brake light switch pressed
    X X X X X X 1 X Brake pedal switch pressed
    X X X X X 1 X X Clutch pedal switch pressed
    X X X X 1 X X X FGR enabled
    X X X 1 X X X X ACC enabled
    X X 1 X X X X X Main button
    0 0 X X X X X X ACC/CCS mode inactive
    1 0 X X X X X X State overspill
    0 1 X X X X X X ACC/CCS in control range
    1 1 X X X X X X ACC not enabled
  3. CCS target speed
    [km/h]
  4. CCS switch settings
    X - X X X X X 1 Locked ON
    X - X X X X 1 X Touched ON
    X - X X X 1 X X Touch-Down, reduce
    X - X X 1 X X X Touch-Up, increase
    X - X 1 X X X X Set
    X - 1 X X X X X Resume
    1 - X X X X X X Locked ON from hardware
007 Temperature senders
  1. Fuel temperature
    to 70 °C
  2. Oil temperature
  1. Intake air temperature
to 75 °C
Warmed-up: 70 ... 110 °C
008 Limiting torques
  1. Engine speed
  1. Internal torque
    At idle: 80 … 110 Nm
       At full throttle: 685 ... 705 Nm
  2. Torque limitation
    At idle: 390 … 420 Nm
       At full throttle: 680 ... 710 Nm
  3. Smoke limitation
    At idle: 210 … 245 Nm
       At full throttle: 770 ... 860 Nm
009 Limiting torques
  1. Engine torque specification
    [Nm] Driver input via accelerator pedal
  2. Limiting torque gearbox control unit
    [Nm] during gearshifting
  3. Limiting torque MSR
    [Nm] of engine drag torque control
  4. Limiting torque TCS
    [Nm] of traction control
010 Air quantities
  1. Air mass
[mg/stroke]
Air mass bank 1 and bank 2 see measured value block 033
  1. Ambient air pressure
    [mbar]
  2. Actual charge pressure
    At idle: 970 … 1020 mbar
    At full throttle: 2130 … 2150 mbar
At ambient air pressure 970 … 1020 mbar
  1. Accelerator pedal position
011 Charge pressure control
  1. Engine speed
  1. Specified charge pressure
At idle: 945 … 950 mbar
  At full throttle: 2144 ... 2145 mbar
  1. Actual charge pressure
    [mbar]
012 Preheating system
  1. Preheating system status
    0 0 0 0 0 0 0 0 Waiting for coolant temperature
    0 0 0 0 0 0 0 1 Waiting for start request
    0 0 0 1 0 0 0 0 Glow period
    0 1 0 1 0 0 0 0 No glow
    1 0 1 1 0 0 0 0 After-glow
    1 1 0 0 0 0 0 0 No start glow
    1 1 1 1 0 0 0 0 Intermediate glow
    0 0 1 1 0 0 0 0 Readiness glow
    0 1 1 1 0 0 0 0 Start glow
    1 0 1 1 0 0 0 1 Waiting for after-glow
    1 1 0 1 0 0 0 0 No after-glow
    1 1 1 1 0 0 0 1 Waiting for intermediate glow
    1 1 1 1 1 1 1 1 No glow
  2. Glow period
    Seconds
3)Vehicle voltage
  voltage
    [°C]
013 Smooth running control
Only readable in engine control unit 2
Vehicle self-diagnosis, Engine electronics II
1)Cyl. 1 Injection quantity variation
  [mg/stroke]
2)Cyl. 2 Injection quantity variation
  [mg/stroke]
3)Cyl. 3 Injection quantity variation
  [mg/stroke]
4)Cyl. 4 Injection quantity variation
  [mg/stroke]
Permissible values at idle: ± 2,99 mg/stroke
  A If the permissible tolerance is exceeded
   Check IQA adaption values (Injector Quantity Adjustment)
014 Smooth running control
–> Vehicle self-diagnosis, Engine electronics II
1)Cyl. 5 Injection quantity variation
  [mg/stroke]
2)Cyl. 6 Injection quantity variation
  [mg/stroke]
3)Cyl. 7 Injection quantity variation
  [mg/stroke]
4)Cyl. 8 Injection quantity variation
  [mg/stroke]
015 Fuel consumption
  1. Engine speed
    [rpm]
  2. Injection quantity
    [mg/stroke]
  3. Fuel consumption
    [ltr/h]
  4. Engine torque specification
    [mg/stroke] Driver input via accelerator pedal
017 Readiness code
  1. EOBD data A
    X - - - 0 0 0 0 No fault messages stored in engine control unit
    0 - - - X X X X Emissions warning lamp (MIL) OFF
    1 - - - X X X X Emissions warning lamp (MIL) OFF
  2. EOBD data B
    • X X - - X 1 - Fuel system monitoring activated
    • X X - - 1 X - Complete system monitoring activated
    • X 0 - - X X - EOBD test fuel system completed with OK
    • 0 X - - X X - EOBD test overall system completed with OK
  3. EOBD data C
    1 - - - - - - - EGR monitoring activated
  4. EOBD data D
    0 - - - - - - - EOBD test EGR completed with OK
019 Fan activation
    [°C]
  2. Vacant
  3. Radiator fan 1 activation
  4. Radiator fan 2 activation
020 AC compressor
  1. Ambient temperature
    [°C]
  2. Vacant
  3. AC compressor shut-off status 1
    X X X X X X X 1 Vehicle starting off
    X X X X X X 1 X Shut-off due to starting off state
    X X X X X 1 X X Vehicle acceleration
                  status
    X X X X 1 X X X Shut-off due to acceleration
    X X X 1 X X X X Shut-off due to starting
    X X 1 X X X X X System fault detected
    X 1 X X X X X X Shut-off due to system fault
    1 X X X X X X X Shut-off due to inadequate idling
                  speed
  4. AC compressor shut-off status 2
        • X X X X 1 Shut-off due to excessive coolant
                 temperature
        • X X X 1 X Shut-off by gearbox control unit
        • X X 1 X X Shut-off by ABS/ESP control unit
        • X 1 X X X Shut-off due to refrigerant pressure or
                 ambient temperature
        • 1 X X X X Minimum on-time
021 Bi-turbo control
  1. Engine speed
  2. Turbocharger calibration
At idle: 0,0 %
  At full throttle: 0 ... 7 %
At 3100 … 3200 rpm (no load): ± 5 %
  1. Charge pressure adjuster bank 1 specification
At idle: 88 … 91 %
  At full throttle: 15 ... 35 %
  1. Charge pressure adjuster bank 2 specification
At idle: 88 … 91 %
022 Rail pressure control
  1. Engine speed
  2. Specified rail pressure
    [bar]
[bar]
  1. Pressure regulating valve activation
At idle: 13 … 20 %
  At full throttle: 38 ... 48 %
  • Values for warmed-up engine
  • Permissible difference between specified and actual value at
Idle: maximum ±20 bar
023 Rail quantity control
  1. Engine speed
  4. Quantity adjuster valve activation
024 Pre-injection 1
  1. Engine speed
  1. Pre-injection 1 start of activation
At idle: 14,5 … 15.5 °CA
        At full throttle: approx. 70 °CA
  1. Pre-injection 1 duration of activation
    At idle: 0,4 … 0.4 ms
       At full throttle: 220 ... 230 ms
  2. Rail pressure actual
025 Pre-injection 2
  1. Engine speed
  1. Pre-injection 2 start of activation
    At idle: 30 … 31 °CA
  2. Pre-injection 2 duration of activation
    At idle: 0,4 … 0.5 ms
027 Adaptive cruise control ACC
  1. ACC specification adjustment
    1 Specification adjustment free-wheeling
    2 Specification adjustment ON
    3 Specification adjustment OFF
  2. Vacant
  3. Vehicle speed
    [km/h]
  4. ACC speed limitation
    [km/h]
028 Accelerator pedal position
  1. Pedal sender
    [V]
  2. Vacant
3)Switch settings
030 Camshaft edges
  1. Engine speed
  1. Vacant
  2. Camshaft edge 1
    At idle: 550 … 575 °CA
  3. Camshaft edge 2
At idle: 625 … 645 °CA
031 Ancillaries
  1. Engine speed
    [rpm]
  2. Internal friction torque
    [Nm]
  3. AC compressor torque
    [Nm]
  4. Alternator output
I know you would have filled more of that in I just posted the small list as a example of my question.
Yes the Label files are filled in, for the V10 engine there is three seperate and slightly different lbl files for engine 01 engine 11 and engine 31
There is also coding info in there so adding things like ACC or towbar etc is easy now
The level contol lbl file allows charging and venting of axles and accumulator which is a great way to test the air suspension.
Just go into basic settings after entering the security access code
Hope its useful
