ABS, ECU, and dash coding. Transmission swap
Does anyone here know ho to code the abs, ecu, and dash? I’m doing my tiptronic to manual transmission swap and don’t know how to code them. I have only gotten one response and it is to completely flash the ecu… Anyone have info on this before I try that?
2005.5 4 4.2 tiptronic.
Transmission came out of a 2007 s4
Thanks!
You will need vag com.
You can go into the engine module and code it from Auto 02 to manual 01.
Keep in mind you will need to make sure you have your clutch switch wired in correctly or the car won’t start. You will also need to make sure your speed sensor and other supporting parts are correctly intergraded.
After talking with people an az and Ross tech’s web site, I have to completely flash the ecu software from auto over to manual software. I’ve been told that with my ecu, it can’t be simply coded. So I guess I’m off to figure this out!
Maybe just try to code the ecu. I just went out and did mine and my dash changed from push brake to start to push clutch to start and my car wont start. But my car is a b6 so maybe its different with a B7. AZ isn’t exactly the hub of factual information.
