Hey all, I want to tap into the brain trust that is on here to see if anyone has run into this issue and what the resolution was. A little while ago I got the dreaded 3 beeps on start up and my ABS, ESP, and Brake lights stay on (brake light flashes). A VAG COM scan shows the following error:
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Control Module Part Number: 8E0 614 517 Q
Component and/or Version: ABS/ESP allrad 3033
Software Coding: 04595
Work Shop Code: WSC 06435
VCID: 3668CB6612E4D3A8CB0
1 Fault Found:
01200 - ABS Valves Supply Voltage
35-00 - -
I checked all the fuses, checked the voltage at different points including the wiring harness (fuses and voltage were all good), and came to the conclusion that the issue is the control module. I sent the control module out to Module Masters for repair. I recently put it back in and am still getting the same error. Before I get back to Module Masters, I wanted to see if anyone had any thoughts on other areas that I can check.
TIA
