ABS pump compatibility
Does anyone know if the ABS pump is interchangeable between the S6 and A6? I’m seeing a lot on ebay that say they fit the S6 but came from an A6.
When I did one 3 years ago in my $1,000 W8, I remember it was from a C5 4.2. Yes I know that is not helpful in the slightest. If it was my S6 I would replace with exact PN.
If you look at the current PN, maybe you can find a 517P, the superceded PN to suite 4F0614517Q
Supersession(s): 4F0910517P; 4F0614517P
I see the 517P is used on other C6 with smaller engines
