[quote=“koolade9,post:14,topic:5684”]
Never had an issue with the Audi, but drawing on recently rebuilding a nightmare of a 30yr old r12 system, some of the basics still apply here…
To the OP, just wanted to note that on the Audi, I do know that you have to add a specific weight of 134a vs. filling solely via low-side pressure reading…and you shouldn’t have to add oil each time you vac, only if you’re dis-assembling and cleaning out the system.
How long did they system sit flat? Did you replace the dryer before trying to vac/charge? That being said, are you able to get all the way to 30in of vac? If you’re getting low pressure codes, that’s certainly why it’s not kicking on, but when charging it, the system should kick on as soon as you hit the low-pressure threshold. That should’ve answered your ‘is the compressor working’ question…
yea im pretty sure it went to 30in of vaccum. he held it there for a while and never moved.
