Yes kinds of. But what Greg posted is also true but you need to put it into context.
Any time you can create a situation where the in coming air charge (ICAC) is cleaner with a higher velocity and density then the crank case air charge (CCAC) your in a better environment. So doing a few WOT pulls every time you drive is a good thing.
Before I go into the explanation the best way to keep the car running well is maintantence and keeping ontop of your oil levels and keeping your oil in good shape.
What Greg posted is 100% true but… the higher engine loads that are conducive to the build up of carbon are… lower rpm higher motor loads were the percentage of CCAC is at a higher percentage and in some cases equal to the ICAC. This would be when your at say 8% throttle but in high gear where the motor is straining or chugging a bit that is to say the motor has a high load on it. These situations create a point where the CCAC is very elevated.
Ideally you always want the larger percentage amount of ICAC over CCAC. That will happen at WOT. The times where carbon build up is when the percentage of CCAC is at its highest compared to the ICAC… This is when your brining in less fresh air (ICAC) and the motor is pulling in more oil air (ICAC) Genreally its pretty impossible to have more CCAC than ICAC but you don’t want the percentage of CCAC to be close to the ICAC.
let me try to explain.
Situations that are high load are slow take off and slow speed driving with constant slow and go. The PCV baffle spring is supposed to reduce the amount of flow at less then optimal conditions but its a spring and things can be made worse if you have a rip in your PVC baffle.
To try and say it another way to help those that might not be following along. ITs like this.
You have two major inlet points going in to your intake manifold and feed into the motor. One point has your throttle body on it and that is roughly 3" and then you have your PCV oil separator and that is about say 1".
Your motor is pulling air into it and it will take air from where ever it gets it. This is why vac leaks cause misfire and fuel codes because the motor is pulling air from a spot that is not measured by the MAF… but let me get back to the point.
You have two points of air entry one from the throttle body (fresh air) and one from the crank case or PCV system (oil or dirty hot air) For ideal power you would just take off the PCV system all together as the oil hot air makes for less power and builds up carbon. But we have a PCV system and we actually need it so lets get again back on track.
******* THIS IS JUST MEANT TO BE AN EXAMPLE I suppose I could do the math on volume and PSI and CFM but this is to help everyone get an idea on what’s going on **************
So your driving and your giving the car little throttle but your going up a small hill. As the car has to go up the hill… the LOAD of the motor or how hard the motor has to work to keep the car going up the hill goes up. In this example you keep your throttle (FRESH AIR) in the same spot and say the throttle plate (FRESH AIR) is at 10% throttle…but since the motor is getting more load the motor is needing and pulling in more air but your throttle position hasn’t changed so now the motor is getting and pulling more air from the PCV system(OIL AIR)… so its now getting a higher percentage of oil air then it was before but your amount of fresh air hasn’t increased… this is true of every time the load goes up and the throttle air amount and the PCV air amount are closer in total amount.
Basically you always want to keep the amount of fresh air well over the amount of PCV air coming into the motor. A good way to see if your motor load is down is to check your instant MPG the better your MPG is generally that goes in line with your motor load…
When you go WOT the amount of fresh air WELL EXCEEDES the amount of PCV air by a grand amount as the PCV system will get to a point where it can’t match the flow of the bigger throttle body your still getting a oil charge but the percentage of oil to fresh air is in a better balance percentage wise.
I don’t know if that made any sense but that’s the best way I can explain PCV percentage air Vs fresh air for carbon build up.
IS an Italian tune up going to get rid of carbon… no probably not I don’t see how it could… if it could youd be sucking carbon into the motor and that would not be a good thing…
Whats the best solution. Maintain the car keep the oil separator in good working order. Keep on top of your oil changes your gastkets etc.
