Strictly what I’ve noticed over the course of several years I listed below. This thread wasn’t designed to bash or make one company stand out over the other but is designed to look back & reflect where the B5 S4 stands today.
After 12+ yrs the B5 S4 seems to be lacking a versatile turbo setup for a reasonable price.
Versatile meaning “a turbo of quality that performs well down low, mid-range & up top without going broke”
[center] [center][b][u]So far we have the usually below[/u][/b][/center][/center]
RS4 K04 setup (good low – great mid range turbo) expensive & hard to get. Than we have the hybrid setups ie larger compressor wheel “no better than the factory RS4 turbo, this has proven to be a large failure for many years. The turbine wheel & housing is far too small “makes the upgraded compressor wheel useless”.
RS6 setup (ok low, great mid – good upper mid range turbo, not much top end) too much money, work & hard to get! With all the modifications needed to make them fit like (cutting, shaving, welding & relocating made these near impossible for the average consumer to take the set of RS6 turbos and make them fit) Than we had very expensive hybrid setups, proved some success but companies abandoned them quickly, the turbine wheel was never addressed properly. Once again to much work, time, talent needed to make them fit. Not practical for the cost of the full setup!
Tial 605 kit (good mid – good upper mid turbo) very large fancy compressor wheel journal bearing turbo with a pretty fairly small turbine wheel in comparison to the compressor wheel, same mistake the hybrids listed above makes in my opinion. Very comparable to the standard RS6 with a little more peak hp gains but you have to run 32+lbs, more expensive, does bolt on but lacks the low – mid that the RS6 has but doesn’t overall outperform the standard RS6 when looking at the complete power band.
Tial 770 kit (good mid – very limited top end) this setup is really expensive, plan on running 35 - 40+lbs of boost to achieve nothing more than your standard GT kit at 26-28lbs, the priciest setups to date for the parts you get or don’t get by the time you’re done collecting all the parts. They don’t come with down pipes or manifolds. For this power band & setup one would do far better with a custom GT kit where turbo selection & custom wheels are wide & readily available. This setup isn’t justifiable with realistic gains to support the overall project cost at all.
GT kits (great mid – insane top end range turbo) not real fun driving at low rpms & speed. I would say strictly for the guy who wishes to go all out from start to finish while addressing the entire car from end to end. Down side “full kit not readily available & if you don’t go all out ie total car build then it’s pointless” When done correctly you’ll have a super car +!! Have check book ready & maybe you’re first born!!!
I know JHM has been talking about getting their B5 program spiced up, maybe JHM or someone can find a much needed in between turbo setup that works in everyday fashion where you don’t need 30+lbs of boost to make for a great all around accelerating car.
Heres the link in the B5 S4 forum…
http://audirevolution.net/forum/index.php?PHPSESSID=4o2vejobklfqntoseutscfg2j4&topic=371.msg5467#msg5467
