Air Conditioning blowing warm air on 2009 A4 - anyone else had this happen yet?
It was about 70 degrees on Saturday so I turned on the AC, but it just blew warm air.
Wondering if anyone has had this happen or has had similar codes…hoping it’s just a replacement of the sensor. Havent seen a DIY on that anywhere, so if you’ve seen one, please link it up.
Wednesday,20,April,2016,09:04:08:02319
VCDS Version: Release 14.10.0
            Address 08: Auto HVAC       Labels: Redir Fail!
Control Module Part Number: 8T1 820 043 AC HW: 8T1 820 043 AC
Component and/or Version: KLIMA 3 ZONEN H06 0140
Software Coding: 64002000
Work Shop Code: WSC 06335 000 00000
VCID: 72E1EA83ADA62EB169F-8027
3 Faults Found:
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 159
Mileage: 133004 km
Time Indication: 0
Date: 2016.01.26
Time: 11:42:11
         Freeze Frame:
                Temperature: 19.0°C
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Reset counter: 159
Mileage: 133004 km
Time Indication: 0
Date: 2016.01.26
Time: 11:42:10
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Reset counter: 146
Mileage: 137565 km
Time Indication: 0
Date: 2016.04.15
Time: 22:25:51
         Freeze Frame:
                Temperature: 17.0°C
                Temperature: 82.0°C
                Load: 0.0 %
                Absolute Pres.: 31.8 bar
                RPM: 0 /min
                Speed: 0.0 km/h
                Current: 0.000 A
                Temperature: 17.0°C
