Alignment off, chirping, ate a tire, now what?
I’ve been having a strange problem in my B6 S4 6 Speed, 19" wheels, 235/45/19 tires, 97k miles, for about 10 days. At first, the alignment was off, and the car would pull to the right. I drove it like this because my alignment shop was booked out for a week. Then it developed a chirping noise that was dependent on speed. No change when brakes applied, clutch depressed, anything like that. A very audible chirp. Then I was driving yesterday, and I heard a clunk, the chirping was gone, and the alignment was back to normal.
I took the wheel off yesterday morning to check it out. The inner surface of the tire had been contacting on the control arm, and has rubbed my tire to the threads. No burst, thankfully. The control arm has worn down a bit from the contact. It looks like the upper control arm bushings have gone too.
I did find that the inner CV boot has torn, so I’ll have to replace that. What else could be causing this problem? Could it be bad control arms? Any other ideas?
Baffled here. Thanks for the help.
Matt
