http://i10.photobucket.com/albums/a129/2fast4sanity/Mobile%20Uploads/image_zpsdvamdy4y.jpeg
Looks much better after swapping the wheels.
The new white looks really nice. Sucks about the crash but it didnt look too bad. I assume you were ok.
Also for me. This definitly says something about your comitment to the 2.0t platform. The crash would have been a good opertunity to move on and no one would have blamed you. To see your sticking with the 2.0 is nice to see.
Nice!
I had too much time and money into the old one to just drop the platform altogether. I also have the EFR and manifold that were ready to go on. I considered an avant, but none of the ones I found checked all the right boxes. To be fair, this one didn’t either because I wanted a black interior. That will be corrected by doing an interior swap with the old car since I have to move all the stereo and meth wiring anyway.
Looking forward to that efr! Nice to know you stuck with it
x2
http://i10.photobucket.com/albums/a129/2fast4sanity/Mobile%20Uploads/image_zpspkqurhu8.jpeg
http://i10.photobucket.com/albums/a129/2fast4sanity/Mobile%20Uploads/image_zpsifvrr3q1.jpeg
http://i10.photobucket.com/albums/a129/2fast4sanity/Mobile%20Uploads/image_zpsxza2yawe.jpeg
Things are happening. I should have the engine in in a couple days once the new motor mounts arrive. Then comes downpipe and charge pipe fabrication.
The attention to detail looks great. Looks like a very well built set up.
Quick question. were you able to pull the motor and not have to open the AC system… It looks like the entire AC system just was able to move out of the way. So no need to re fill the system with a motor pull
You are 100% correct. You just drop the evaporator from the core support, unbolt and disconnect the wiring from the compressor and swing the whole shebang off to the passenger side and out of the way.
I decided to take a day off of work to work on the car. Exhaust is now complete (until I decide to redo the Y-pipe).
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsvmysnms9.jpeg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps0aodm6ct.jpeg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsx6wneilc.jpeg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsiybdsvop.jpeg
Currently ongoing projects are the headlights (in pieces in my basement awaiting a part) and the refinishing of the trunk and front lip spoilers. They will be getting painted black, but I haven’t yet decided on gloss or satin.
Turbosmart dual port actuator required some chopping and welding to get it to fit, but it’s on.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsfqrbdlgi.jpeg
All lines finished and covered with fire sleeve.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsncea1etm.jpeg
Coil harness moved out of the danger zone. I’ll redo the heat wrap with the snap kind down the road but this should work for now.
[URL=http://s10.photobucket.com/user/2fast4sanity/media/image_zpsvgu6bkx4.jpeg.html]
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsvgu6bkx4.jpeg
Are you sticking with maestro again for tuning?
Nope, it was a good run but I wasn’t paying another $500 to use Maestro on the new car. I’m going with doTuning for the new setup.
Oh, gotcha! Hope that works out!
Flashing the base file.
http://i10.photobucket.com/albums/a129/2fast4sanity/Mobile%20Uploads/image_zpsmetqtnc7.jpeg
First start
http://youtu.be/xXpnwvK7mc4
Woot!
Nice! Now let’s see it spooool!!!
Took it out on the highway today to see how it behaves. Still on the base file, but I’m getting 24 psi at 3k rpm in 6th. Not quite as fast in the lower gears, but I think that it’s safe to say that I gave up ZERO spool coming from the K0R. The response of this turbo is ridiculous for its size.
you can really load up the turbo in 6th gear it would be interesting to see how it spools in more usable siuations and gears
In 3rd gear, I’m seeing roughly 18 psi at 3k rpm. It’s hard to tell exactly because the current boost gauge is a vent gauge that’s hard to get a good look at safely while driving.
