What is your reasoning then? Where is the proof? its in the pudding, show me the pudding.
Stolen from NASIOC
http://i824.photobucket.com/albums/zz161/jkopinga/Dyno%20Sheets/83_-75_3_hotside_comparison.jpg
"In this dyno sheet you can see the overlay of the BW 83-75 with 3 different hotsides:
- Twin Scroll 1.00 A/R running 30 Psi boost pressure
- Twin Scroll 0.91 A/R running 30 Psi boost pressure
- Single Scroll 0.88 A/R running 25 Psi boost pressure"
Looks like it makes a pretty damn big difference to me. Not sure if the effect is different with a smaller turbo on a smaller engine though. If I’m spending the money for a tubular manifold over the T25 APR manifold I already have, you can bet your ass it will be twinscroll.
What is GenerationJDM? Is that a shop? If you’re a shop joining the site, try to use firstname@shopname so it’s clear who you are.
I’m not sure but that ceramic coated mani looks a lot like the old vast mani’s
Leaving these here for quick reference and for everyone else’s info.
3/8’s is a little thin i’d look for 1/2in, 034 makes the best one IMO.
http://store.034motorsport.com/exhaust-manifold-flange-2-0t-fsi-2-0-tfsi-2-0-tsi.html
Guess I didn’t look hard enough the first time.
t4 or t3?
t4 or t3?
for what?
mec:
t4 or t3?
for what?
The collectors both the treadstone and sparktec don’t specify. And twinscroll comes in many mani sizes
Derrek:
mec:
t4 or t3?
for what?
It doesn’t say specifically, but it is designed for the EFR series. Twin scroll EFRs are all T4.
Derrek:
mec:
t4 or t3?
for what?
Treadstone says t4 but it’s 1.50, personally I’d want to use 1.25
mec:
Derrek:
mec:
t4 or t3?
for what?
Sent from my iPhone using Tapatalk
Edit: is not says
Derrek:
mec:
Derrek:
mec:
t4 or t3?
for what?
Edit: is not says
1.25…what measurement is that? port diameter?
Derrek:
Derrek:
mec:
Derrek:
mec:
t4 or t3?
for what?
Edit: is not says
runner diameter. You can use 1.50 but you spool later, it’s mostly used for better top end and larger displacement motors.
ohh gotcha, i think mine were 3 or 5 16ths
I tried a few times, but it kicked my ass.
I like the way this looks better though…
now that you’ve upped the boost the turbine housing part is all messed up. Here’s the one I’ve been messing with.
