Another AC issues thread
Like a few others on here, I’ve been having some issues with my AC. My previous issue (no cold air at all), was due to a bad compressor. That was replaced about a month ago, and since then I never felt the air get as cold as it I believe it should. If I get the temp to 63F, on 90+ days the interior just doesn’t get as cold as my wife’s mdx. The interior does get cool, but not that frigid air that I expect when the temp is set so low.
Any thoughts on what might be causing this?
I logged the HVAC and attached some of the values.
https://lh6.googleusercontent.com/-dFX2nhwAKhY/U8WJvTYKhjI/AAAAAAABgy8/RhmNdGmdGik/w1159-h93-no/LOG-07152014_AC+components.png
Sorry for the crude image.
Also… just recently I threw a high pressure sensor fault and will be replacing that shortly.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6DDA0E552792D676401-5120
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
