Another APR TVSr1740 kit blowing an engine. Fried piston rings.
http://www.audiclubsa.org.za/cgi-bin/yabb25/YaBB.pl?num=1428549092
and the analysis from his shop
[quote]Once the heads were removed we could see more and get a better idea of the actual damage. The damage were major. First we noticed the damaged o-ring on the high pressure fuel pump.The o-ring were partially melted due to either excessive heat or was damaged when fitted. Upon inspection its visibly clear that the left bank suffered more damage than the right. Piston no 1 were running very lean and combustion abnormality associated with abnormal high combustion temperatures occurred in this cylinder. The aluminium on the head was burnt clean and the piston surface was also burnt clean, the aluminium suffered flame erosion. This corresponds with the spark plug condition of cylinder no. 1.
Piston no.2 however suffered far more damage than cylinder no.1. This piston suffered to the point where the rings can be seen and the rings got burnt through. Also the skirt of the piston broke off. The cylinder side wall also known as the sleeve got burnt and damaged in the process. The cylinder head material also turned porous in this cylinder. Failure of this cylinder is due to very lean fuel mixtures combined with boost (compressed air). Flame erosion destroyed the components in this cylinder.
