Alright here we go. I just talked to my buddy who runs parts at audi dealer and used to own a C6 V10 also. He said the injectors FAIL and must be replaced, they fail un-related to carbon. Is this true?
I have almost everything ready to re-do my engine:
- Walnut blaster
- Walnut shells (fine grit)
- New IM
- On the way JHM spacers, SAI DEL, heater bypass, etc
- Have yet to purchase - O-Ring kit for injectors
I was planning to ship the injectors out to be ultra-sonic cleaned and flow tested. Now I am stressed that I need to buy new injectors.
What did you guys do?
IMO $1,700 for injectors doesnt make sense. Checking my repair history I see they purchased 06E998907 meaning the injectors are original when the put in the new engine 07l100031ax, I assume the old one blew up because of a failed injector (s)!!! :-[
I was getting some flashing CEL occasionally, usually the codes were for misfires on 8 and 4, sometimes 7 and 2, random, go away when warm. Also got some codes once while driving “hot engine” for P0171, P0174, P0175 “system too lean” bank 1 and 2. I assumed these all to be Carbon / IM related. I think some air may be sneaking into the IM through the broken IM flap hole…
