Thanks guys. It was a BIG step and a huge dream come true. It’s still a bit surreal. She obviously was someone’s baby before me and they dumped a ton of money into her (all to my advantage!).
She’s a 1968 model 36 Bonanza with just shy of 9000 total airframe hours (but Beechcraft are some of the best built planes on the market and are built to do 20,000hrs if maintained). The engine has ~1100hrs and has a TBO (overhaul) at 1800hrs. I’ll probably swap in the IO-550 engine at that point though (~38k for overhaul or $50k for new 550 engine).
Previous owner installed new engine in 2001, did paint and interior fresh around 2006, and then major panel upgrade in 2008, and then installed the Turbo Normalizer kit in 2010 ($40k for just the TN kit) with a new prop at that time as well. So there’s not much that hasn’t been touched. I had a really good mechanical pre-inspection done and then once I flew her it was a done deal and closed on her yesterday. Plane was based out of north Atlanta, but seller flew her up here since I’m not checked out in the make/model yet to fly solo in it (just a matter of some instruction). I am IFR rated and obviously High Performance and Complex endorsed but lower total time due to inconvenience of renting, but plan on that changing quickly lol.
Anyhow, for anyone that knows what it means, avionics wise it has:
Dual Garmin 530 with WAAS
Garmin 200 MFD
Stec 55x autopilot with GNSS
JPI 700 engine monitor with gps coupled fuel flow
HSI and backup electric attitude indicator
Previous owner probably spent north of $50k for the avionics upgrade at the time =)
As far as range, speed, UL (useful load), etc.
-at cruise it’ll burn around 12.5gph running LOP (lean of peak) and should cruise at ~150-155IAS around 12,000ft which is closer to 165TAS or ~185mph ground speed. Go higher and it gets even better! (But oxygen is needed)
-Running it ROP (rich of peak) picks up another 5-7knts but at the cost of 6-7 more gph and the engine like burning cleaner LOP anyhow
-max gross weight is 3792 in its current configuration (Tip Tanks raised it from 3600), if I went to the IO-550 engine it’d go to 4,000#. Basic empty weight (everything but fuel & passengers) is 2394. So each # of 100LL weighs 6# and technically it can carry 110 gallons of fuel (80 in mains and 30 tot in tips). But you can figure that at 12gph LOP that’d put you in the air way longer than you bladder could hold and cuts into your UL pretty significantly. More likely is carrying ~50-70 gallons and the passengers/baggage you want.
-it’s technically a 6 person plane, but that’s based on 170# passengers and thus only half fuel. I’m pulling the rear two seats as there isn’t enough space there anyhow and that’ll get me ~40# back and some good baggage space.
Anyhow, it’s the pictures that count right lol. So here’s the fun stuff.
http://images.tapatalk-cdn.com/15/12/04/23f29bb2235e03fc5528b559faaec0f2.jpg
http://images.tapatalk-cdn.com/15/12/04/a86bf63b394e84ab57fe767e2a92e847.jpg
http://images.tapatalk-cdn.com/15/12/04/e059208082d888cb76c94d1dc6010190.jpg
http://images.tapatalk-cdn.com/15/12/04/d38e6fc6c68f3fcc8a42fc1eb328b810.jpg
As far as a representative of speed/range/possibilities. Here’s a quick example from Nashville to Tampa FL based of the numbers I’ve calculated (haven’t flown enough to completely iron them out but should be close).
533nm ~3.5hr ~48gal -> carry 60-65gal this 375# in fuel so it leaves 1025# for passengers and baggage.
http://images.tapatalk-cdn.com/15/12/04/3f650960156fb596b6c4426d8a42dacd.jpg
Also, for the engine geeks, the “fixed speed” props with engine monitors is really pretty sweet. You manually control propeller efficiency and obviously have control of mixture as well as manifold pressure.
And with the engine monitor, it reports INDIVIDUAL cylinder EGT, CHT, TIT (Turbine inlet temp), fuel flow, total fuel remaining, voltage, difference between max/min cylinder, “lean find” which calculates which cylinder hits peak EGT FIRST so that you can pull temps back based on that cylinder, oil temp/pressure and a lot more. Also will allow you to record and download past 100hrs of info.
http://images.tapatalk-cdn.com/15/12/04/769935e98fee3f3bb8a6aace9346e0bc.jpg
