Interesting… I had something happen to me about 2 weeks ago. Car was running great, shut it off for about 10min, started it back up and died, then tried to start it and could hear starter kicking over but damn thing didn’t start. Just keep cranking and never started.
At the time, I scanned engine and didn’t get any engine codes. I let it sit for about 20min to cool down (was driving pretty aggresive at the time) and it started right up without a hiccup. I did a full scan when I got home and it caused a fault in steering wheel module:
I was having weird issues with my remote and wondered if it was just the battery. I changed the battery on the remote and since that day it hasn’t happened again (just not really sure if its the remote). Without any other codes or symptoms, I’m left to think maybe transponder issue??!!
It just occurred to me a common issue on the old mercedes is a check-valve after the accumulator to keep fuel from draining back from the engine. I’m sure we have a similar valve, and IIRC, it’s in the fuel filter (can anyone confirm?)…when’s the last time you changed yours?
Immo is usually just like an RFID chip in the key, that gets interrogated by the instrument cluster. Likely not RFID, but similar. Passive device in the key, powered bit in the cluster. The key battery powers the lock/unlock transmitter, but probably not the immo.
Officially it is lifetime. I replace my S4’s regularly but that is because I want max performance and my car sits for long periods of time so the fuel starts to break down.
