Service at 5,000 miles (8,000 km) or 6 months after delivery, whichever occurs first.
Engine oil/filter
Service reminder indicator display- reset
Check the following:
windshield wiper and washer/ headlight washer- add fluid if necessary
tire and spare wheel- check for wear and damage. Rotate tires. Check tire pressure.
Road test- Check braking, kick down, steering, electrical, HVAC system, automatic shift lock,
and power accessories.
Every 2 years regardless of mileage/kilometers:
Cloth top:
Check function and roll-over protection with cloth top down.
(Audi A4/S4 cabriolet only)
Service at 15,000 miles (25,000 km) or 1 year after last service, whichever occurs first.
Engine oil/filter
Engine-check for leaks
Engine-OBD, check fault memory
Service reminder indicator, reset
Dust and pollen filter-replace
Check the following for leaks/damage/ add if necessary:
cooling system
exhaust system
battery
AT and final drive
MT and final drive
Tires/spare wheel
Brake system
Doors- Lubricate hinge mechanisms
Sliding roof
Lights
Drive shafts
Front axle- Check dust seals on ball joints and tie rod ends, check tie rods
Snow screen for air cleaner- Cab only
Replace brake fluid( every 2 years regardless of mileage.)
Cloth top:
Service at 25,000 miles (40,000 km) or 1 year after last service, whichever occurs first.
Engine oil/filter
Service reminder, reset
Cloth top:
Service at 35,000 miles (55,000 km) or 1 year after last service, whichever occurs first.
Engine oil/filter
cooling system
exhaust system
battery
AT and final drive
MT and final drive
Tires/spare wheel
Brake system
Continuously variable transmission (Multitronic) Change ATF
Sliding roof
Lights
Drive shafts
Power steering fluid
Cloth top:
Service at 45,000 miles (70,000 km) or 1 year after last service, whichever occurs first.
Engine oil/filter
Cloth top:
