I posted this data over at AudiZine but I figured I’d post it here as well.
After lots of talk of “BEL” blocks I started examining blocks I have and found 4 versions:
Block versions:
Version 1:
APB - Early, 2001 and before :
Part Number ### ### ### A*
No identification marking between banks
Producstion Year 1999
Block stamped APB
Plastic bolt in crank lock pin plug
Outer Main Bolts go through Main Web into “window”
Outer and Inner Main Bolts the same length
Window ~ 50mm wide
Window to Main Journal ~ 13mm
Version 2:
APB - ??? :
Part Number ### ### ### BF
Block stamped APB
Outer Main Bolts do NOT go through Main Web into “window”, stronger
Outer Main Bolts shorter than Inner Main Bolts.
Window ~ 40mm wide
Window to Main Journal ~ 16mm
Version 3:
APB - Late, 2001.5 and after :
“BF” identification marking between banks
Producstion Year 2000
Block stamped APB
Window ~ 40mm wide
Version 4:
“BEL” - 2003+??? :
Producstion Year 2001+
Block stamped APB
Screw in metal crank lock pin plug
Window ~ 40mm wide
More here:
http://www.audizine.com/forum/showthread.php/527211-BEL-vs-APB
