Good stuff. That’s a solid trap speed and good ET. Post your modlist again…hard to remember.
You’re still losing lots of time in 1st, 2nd and the shift into 3rd. For perspective, a well run 1/4 mile pass will generally see the 1/8 mile time mulitplied by 1.55 to equal the 1/4 mile time.
If we look at your 1/8 mile (and 330) it is that of a mid to low 12s car.
If we look at your trap speeds vs. B5 S4 gearing and good runs, you’re in the range of 11.4-11.5 cars.
So either the single is just too hard to spool up in the first couple of gears and that puts you behind the 8 ball for the first 2 gears, or you need to work on your shifting. Or launching. Or all three. Now…I’m speaking with respect to being AWESOME and getting everything out of your setup. If you’re not that interested in that and just want a good feel for the car and it’s capabilities, the 124 tells you it’s DEFINITELY producing good power and running in the 11s is not easy for anyone. I watched a C6 Z06 with cams and exhaust struggle to get an 11.8 after half a dozen passes last weekend.
All in all , good result and exciting to see. As I mentioned, post the modlist so I can add you to the list.
and a video without a description is annoying haha.
