i cannot post images via additional options/attachment.
i get an error saying that the site upload folder is full and to contact admin.
can this be fixed so i can update my thread.
thank you
thank you
not sure what that means, but what you need to do is
a) go to tinypic
b) load up your image
c) copy the [img]http://xxxxxxxxxxxxxxxxx.jpg[ /img] link
d) paste that in your thread
Thank you for taking the time to post this question.
If you’re uploading a picture check the size and format. Then keep the name of the picture title small with no dashes.
Please try that and the suggested option listed above. From that conclusion share your results.
i am using my own img host to post my pics as of now…using link
but using that method the pics show up smaller.
so instead i want to use your internal attachment option…i use .jpg format picture that under 128k…mine are about 87k
i get this error
The upload folder is full. Please try a smaller file and/or contact an administrator.
ok problem fixed…
i shortened img name and found out that one img was 132k and not what my comp was telling me.
my apologies.
thanks for your help
Thank you for the update. Loading your pictures here helps you and the community. The name title rejection feature is on the list of bugs to fix.
If you have any further issies feel free to post them here.
do you know why my pics using an img host show up so small on site\
http://audirevolution.net/forum/index.php?topic=1988.0
they are a high resolution so should be bigger
and scratch my other post…its still not working. Its got to be on your end.
My pic has the title of 1.jpg and is 68k and i still get
An Error Has Occurred!
I have this solved now…its the imghost im using they blow.
used imggur and problem solved.
although your internal attachment option is still an issue
