Audi C6 TSB List
Audi A6 TSB List
a6_tsb
Alignment and Suspension
Alignment - Vehicle pulls to one side
Alignment - Wheel bolts require torque adjustment
Brakes
Brake Pulsation Diagnostic 2022584-1
Brake pulsation diagnostic guidelines
Brakes make moaning or muh noise when accelerating from stop or turning at slow speeds
Brakes squeal
Brakes Squeal 2017130-8
Electronic parking brake warning light on; parking brake doesn’t always release
Coolant and Radiator
Coolant Reservoir, Appears to be Leaking
Coolant warning light comes on in cold weather
Electrical
64 Power window switch is sticking
Airbag Pyrotechnic Safety Belt deployment, inquiries
Airbag Warning Light on update for airbag module software
Battery Dead (2)
Battery testing with 5051 5051B 5052 scan too charging with Midtronics InCharge 940 INC-940 char
Battery Warning Light - Light Flickers
Best of XM stations not available 2021273-1
CD Playback Problems with non-standard CDS 2013159-4
Central locking locks up when removing ignition key from ignition lock
Coming or leaving home function intermittently does not work when unlocking doors with the remot
Convenience close open feature of the door windows does not work
Convenienceclose-open feature of windows and-or sunroof does not work 2016535-4
Doors lock without customer input after exiting vehicle
Doors lock without customer input after exiting vehicle 2015226-3
DTC in Electronic Central Electronics J519 after replacing Steering Column Electronics J527
DTC Sporadic - Contact Check 2013504-5
DTCs, sporadic - contact check
Easy Entry function of the power adjustable steering column intermittently does not work
Electric steering column adjustment is inoperative
Electrical - Mult-function steering wheel inoperative (2)
Electrical components malfunctioning after windows have been tinted
Electrical failures or component malfunctions - Wire harness repairs
Emergency Flasher Switch -E229-, Light Flickers
ESP light on (DTC Please read engine control unit)
Fault entry in vehicle electrical system control module
Fuel gauge does not go to Full after filling up
Fuel gauge reads empty after refueling
Hand sensor for garage door opener cannot be adjusted to HomeLink system
Instrument Cluster Service Interval Programming
Missing outside temperature in IP cluster display
Multifunction Steering Wheel, Controls Inoperative
Parking aid warning sound without obstacle
Power folding rearview malfunction 2016043-3 3
Power folding rearview mirror malfunction
Telematics system, switching off emergency battery
Trip mileage counter inoperative
Voice Recognition System, Cancels Request
Window lift switch is sticking
Engine
4 2 FSI RVU for ECM update
Coil Pack Recall
Cold engine runs rough or stumbles; warm engine may stall when engaging gear and vehicle is
Engine - Camshafter Adjustment
Engine Intake Manifold Mounting Bolt Torque
Engine oils that meet Audi Oil Quality Standards 502 00 - 505 01 - and 504 00 - 507 00
Engine Repairing
Engine replacement, checking for debris lodged in transferred assemblies
Engine Starts Hard or Held in Crank for a Long Time
MIL after performing coil pack TSB 2023120-1
MIL is flashing or constantly illuminated, and DTCs for misfire in one or more cylinders
MIL on - misfire DTC stored after cold start
MIL on (P129F, P310B, P2539, P2540, P2541 or P2543 stored)
MIL on DTCs for misfire P0300 - P0312 - Coil Packs
MIL on Gasoline Quality 2014753-7
MIL on gasoline quality DTC P0300 or P030x lean condition DTCs
Oil consumption measurement
Oil Consumption Measurement 2018550-7
Oil Leaks From Upper Engine Areas
Rattle or knocking noise from camshaft adjuster at engine start
RVU - 3.2 V6 FSI ECM update
RVU - Fuel pressure sensor replacement
Software Version Management (SVM) operating instructions
Software Version Management (SVM) operating instructions engine chirping and hooting
Software Version Management SVM operating instructions 2011732-8
The MIL is flashing or constantly illuminated, and DTCs for misfire in one or more cylinders
Vehicle lacks power or will not move after stop
Exterior Noises
A-Pillar and Roof Bar Make Cracking Noises
Noises from lower door hinge
Noises from lower door hinge 2018319-3
Rattle noise from engine area
Rattling Noises When Shutting Doors
RVU - Thumping, knocking or popping noise in fuel tank area
Thumping noise from the rear of the vehicle
Whining noises from fuel system
Whining noises from the fuel tank
Fuel Issues
Fuel Filler Flap, Will Not Function
Fuel Pressure Sensor (2)
Fuel tank removed from vehicle, neutralizing fuel
Fuel-filling problems
HVAC
Air conditioning inoperative
Air conditioning inoperative 2020124-2
Cleaning of the air conditioning refrigerant circuit
Climate system may not cool sufficiently
Climate System, May Not Cool Sufficiently
Driver side cooler than passenger side
Temperature different between front driver and passenger sides
Unpleasant odor from heating and ventilation system
Ignition and Keys
Battery discharged on vehicles with Advanced Key
Battery Discharged on vehicles with advanced key 2019143-5
Engine intermittently or consistently does not start using advance key start button, starts w ke
Engine intermittently or consistently does not start using advance key start button, starts w key and ignition switch
Ignition key cannot be removed when transmission is in park or cannot lock vehicle
Ignition switch cannot be turned on; key may stick in ignition; engine will not start
Individual doors sporadically cannot be unlocked with the remote key
Personalized memory settings of the key are not available
Programing Keys
Remote control key inoperative
Remote control key inoperative 2017082-9
Remote transmitter key does not function remotely and or red panic button missing
Remote Transmitter Key Electronically Does Not Lock Unlock Doors or Trunk and or Red Panic But
Vehicle Locking System Diagnostic 2022032-2
Vehicle locking system, diagnostic information
Interior Noises
Dashboard - Rattling Noises from Left Windshield Area
Driver door trim panel requires replacement 2022154-1
Front center arm rest cover fails to open
Front seat free play is perceived by customer as excessive
Noises from front door speaker
Noises from sunroof 2022733-2
Noises from the center console
Noises in dashboard area
Rattling noise from front headrests
Sunroof rattle
Whistling Noises Come From the Ventilation Dashboard Vent
Whistling Noises Come From the Ventilation Dashboard Vents
Lights
Adaptive lighting, headlight range control warning
Automatic Headlight switches on and off with no reason 2016808-3
Automatic headlight switches on and off without reason
Condensation on taillight lens
Daytime running lights do not work
Dynamic headlight range control warning light is on in the instrument cluster center display
Exterior lights, moisture accumulation
Headlights vibrate
Headlights, aiming using Hella Universal Beamsetter IV
Miscellaneous Items
Airbag, replacement interval change
audi 2005 fluid
audi 2005 maintenance sched (2)
Windshield wipers streak, smear or are noisy
MMI
Cursor is jumping in radio memory list (possible Navigation DVD upgrade)
Eng Oil Level Option in Car Menu of the MMI Does Not Work.
MMI - difficulties below 40 degrees
MMI - inoperative at ambient temperatures below 40 degrees
MMI cannot be operated via Multi steering wheel operation
MMI car systems does not contain the option Instrument Cluster 2020250-2
MMI Car Systems menu contains grayed-out Windows option
MMI Car Systems menu does not contain the option Instrument Cluster
MMI Display screen is white or flickers
MMI displays inaccurate battery charge state
MMI High Some functions unavailable after 07 - Display control unit replacement or MMI Zug softw
MMI High System software update Zug 864 - update procedure
MMI inoperative below 40 degrees
MMI Surround setting lost
Multimedia Control Head E380 button sticking, obvious outside influence
Only one satellite radio station is displayed and playing with activated Tuner
Navigation
Navigation DVD can not be ejected
Navigation not available displayed on MMI screen
Navigation vehicle symbol jumps in map overview
Please chech Navigation DVD
Reading Audi Codes
AudiDTCCodes
Stereo
AMI functioning normally (DTC 02076 no signal to media player in Gateway Control Unit)
Audio system does not recognize or play AAC formatted files
BOSE 4000 Amplifier - No audio or screeching sound in very cold condition
Bose Sound System without function, no sound
CD Error Message Displayed in Radio Display
CD playback problems with nonstandard CDs
No bass on rear fader
Radio - Satelite attena
Radio ? No Bass, if Fader is Adjusted Fully to The Rear
Radio inoperative below 40 degrees
Radio is Inoperative in Satellite Mode, Vehicles equipped with J533 (Gateway)
Satellite Radio (SDARS) Activation Information
Satellite Radio (SDARS) Error Messages and Satellite Drop Out Diagnosis
Sound system - interference
Sound Volume Changes After Ignition Off-On
Sunroof
Sliding Roof Reverses, Does Not Close Completely
Sunroof has functional problems, headlining loose
Sunroof headliner does not tilt correctly when sunroof panel is vented
Sunroof headliner -glass roof jammed - not moving - sunroof not opening - closing correctly
Water Marks on the Headlining Water Drain Hose of Sunroof Kinked
Telephone
Bluetooth Phone preparation LG VX8700 drops Bluetooth connection
Echo, crackling noise while on phone via Bluetooth connection
Hands free phone function is inoperative 2022701-1
No phonebook and - or call list download from cell phone to MMI system after MMI software update
Phone volume lowers intermittently during call
RVU - Repairing telephone preparation
Voice dialog system doesn’t work on vehicles with phone preparation
TPMS
Audi Tire Pressure Monitoring Systems overview
DTC 01521 stored in the Tire Pressure Monitoring System (TPMS)
TPMS diagnosis A4 (B7), A6 (C6), & Audi Q7
TPMS diagnosis with BRT-DBL4
TPMS Overview
Transmission
ATF pan leaks
audi tb 37-06-13
Bucking when accelerating from a standstill
Chirping, hooting, squeaking noise when shifting between 3-4
No drive or delayed drive in D or R
Torque converter clutch circuit performance or stuck off
Transmission in Emergency Running Mode
Whining noises from rear axle
Trunk Compartment
Hook for trunk lining handle out of position
Hook for Trunk lining handle out of position 2018538-4
Luggage compartment side trim loose
Trim for Tailgate Noisy
trunk cover falls out
Thought I would help post the list of whats all on the TSB. That’s a long list.
Perfect! thanks
I was not the person who put the page together, but volunteered to help keep it alive after the author sold his C6 A6.
I am sure the info will come in handy around here.
