Not yet we are still waiting Ape is on the case tho !
Hello Ray,
Just copied your design for catch can, used 20mm ID silicon hoses and plastic fittings 90 elbow and T
wanted to ask you what fittings you used, I’m worried the plastic ones I’m using might melt down or deform from heat ?
also the special mount for the can it self, could you elaborate more on that or share a photo or design ?
thanks
@a_ibrahem Hi buddy.
Apologies for the late reply! Awesome work you done there buddy! Should be really proud of your work! I too have used plastic fittings 90 elbows and T bends. I more than fit for purpose for the job, so no need to worry there. But if you are worried I believe you can get those 19mm I.D fittings in brass.
With the mount for the catch can it was just abit of straight aluminium plate about 30-35mm wide and 4mm thick that I painted black to make it look more OEM. I then M6 threaded the plate so that the two bolts would screw on it plate in to position and even added nuts underneath to make it more secure to the frame of the car.
With the bolts for the catch can I just drill two holes through the plate and use the fixing bolts supplied with the kit to attach the can. Hope this helps.
From the first image I have posted I have made some alterations with the pipe work fittings will get a picture up asap for you to see
Hi Ray,
Thanks lot for reply, appreciate good word
Believe will be do something similar to mount the can
What hoses are you using ?,looks more slim and flexible than my silicon 20mm ID than I’m using
Waiting for the new pipe work photo
Hi @Ray_86,
here is my attempt to do similar mount, definitely your looks better, but its holding strong and does the job
don’t forget pic for new pipe work @Ray_86 please
Trying to do a catch can setup for an s6, where did you find your connectors to the valve covers?
I used the factory ones, heated PCV hoses and removed the hose from connector
i remember i saw them also on AliExpress
Again sorry for the late reply, been busy with work but I haven’t forgotten. Here are the images of the new pipe work alterations made on the return line. I’ve have circled what I have change it basically uses less plastic fixtures and changed with manufacturer silicone/EPDM hose bends. Think the alterations look a fair bit better more OEM.
no worries man appreciate your help,
Definitely looks better
where you got those hoses ? was it a custom order ?
I had some feedbacks that silicon hoses are not suitable for any oil/fuel
so I replaced all hoses again with Gates PCV/EEC hoses, it looks more OEM also
The hoses are not a special order, it was just another straight off the shelf item. Thanks man I too agree it looks better be good to see how the new piping you have install looks now too
I was trying to find the same and not able to reach anything, where i live we don’t have local stores that sell such hoses, i have to order everything from states, would be interested to order same if i know from where.
also what size are those hoses ID ?
sure will take a pic soon for you
Here is new hose from Gates
Also got some Torx screws to secure the Can, it matches more the OEM style
Would you be able to hook me up with similar hoses like yours ?
Shop name or website to order ?
What brands of Catch cans are you guys using? Does yours have any media (Stainless, Brass, Aluminum) inside the Catch can to help vapors condense?
I recommend Mishimoto’s 50 micron catch can. You can get it on Amazon. I ran it for years in my 335is and it performed wonderfully.
Looks very nice that does buddy! I like how your catch can is slightly turned so that the pipes haven’t got much of a bend radius.
The I.D is 19mm and I bought all my fixtures and fittings on eBay. The type of hoses you would want is called EPDM braided hose.
This is the catch can I have used, and if fits into the space perfectly.
Thanks mate ,will look those hoses up on ebay,
That’s exactly can I’m using as well, ports fits straight to 19mm hose so no need additional fittings
Installing a Catch can today to include using the OEM intake valves. How much oil have you guys been catching in the RS5? I do see a benefit into venting to atmosphere if a lot of vapor gets by the Catchcan. By venting to atmosphere and blocking the valves does it cause any crankcase pressure issues? Thoughts?
My observation was with one somewhat failed PCV valve, more air was forced in into the intake from the crankcase via the PCV, probably producing more power; it definitely increased fuel consumption. Given that it is venturi tubing/piping from the pcv this increases airflow disproportionately in relation to the diameter of the tubes and different passages in the upper intake (I assume). Installing the new PCV valve also definitely decreased oil consumption.
I have no proof, but in principle should want all unclean mixtures out of the crankcase asap and the vacuum is certainly strong.
If it runs just like with two new PCV valves, should be as good except any potential benefit of blow by being combusted (potential lubrication) not happening.
I know forced induction cars tend to generate more PCV bypass with the higher chamber/cylinder pressures but with the RS5’s high RPM’s it has to generate a fair amount. And we all know they need regular Carbon cleaning. Even if it only reduces the carbon cleaning a little, it also has the benefit of feeding your car a better Air/Fuel mixture instead of ‘partially to unburnt’ gases which is almost like lowering your Octane a little, maybe not seat of the pants meaureable but has to be more power.
You know…with the JHM billet PCV kit, it would not be hard to integrate a catch can setup. I’ve actually been meaning to do this for some time but haven’t figured out how to go without sleep yet. But I’ll dive into it as long as everyone understands it will do very little to reduce carbon buildup.
