friends I have an audi s6 2010 v10 I have several problems I go to the mechanic and the dealer and they cannot solve the problem this are the codes I have, help me to see if I change the parts myself
We can all help.
a few things you can do. Order a ross tech vag com. We can have you post up all of the digital information you recieve.
The codes are important but clearing the codes and seeing the results from each event. you can log things and then go from there. The codes are the begginning of the journey. But either way we can all help you if you have the simple tool.
I’d agree with @justincredible and order the ross-tech vcds. Outside of the scan showing multiple codes, can you tell if there is anything else mechanically wrong? Rough idle, rough shifting, or brake responsiveness? I know the codes are for multiple systems, but if you haven’t noticed an actual issue then I’d lean towards an electrical issue.
If I had to guess I’d say your battery is low. The only reason I say this is because I had multiple random codes on my 4.2 with the Open Circuit/Implausible Signal/Abnormal showing up. It wasn’t throwing a CEL, but when I ran a scan I saw them. I couldn’t figure out how to clear them for the life of me. When I put the car in storage for the winter I hooked it up to a battery charger, and once spring rolled around I ran another scan to make sure everything was in working order. Magically the codes were cleared. I’m assuming there just wasn’t enough voltage to the sensors.
Ufff ok
Nothing looks so hard that you can’t tackle this on your own. But I don’t know your mechanical ability.
