Probably going to have to take it to a dealer or if you can find someone that can program it for you
I had my car programmed by a guy he did my ecu and all the stupid modules that went into component protection for the interior of the car and my transmission when I changed it
So yeah you can take it to someone else if you can find someone by wherever you are or just take it to the dealer
Also even independent shops if they have the software to do it
Wow that looks terrible GREAT find. it looks like this was water damage?
Just so I understand you didn’t bypass the relay you just changed out the fuse holder with something you made that is in better condition than what you found?
They looked like my relays from the water damage I had when I got the car from auction
Yeah, looked like they got wet at some point
No doubt got wet at some point, yeah totally changed out fuse and holder and made one up. As for the relay cleaned up the holder and replaced the fuse. I never knew about that fuse and relay location, found it by chance. No information on line at all.
Yeah exactly, easy fix, hard part was finding it
