Hello,
I waited to become a member of this forum from summer and yesterday I wrote why isn’t my account approved… FINALLY I may tell!
I bought my first “super-luxury” car. Have owned before hand 1x Q7 V8 TDI, 1x Q7 3.0 TDI, 1x A6 C6 Allroad and now an S6 C6. All have been much fun, but I miss the V8 TDI the most, I managed to chip it to over 300kw and that was a beast. Now I’m dreaming to get an Q7 V12
Now onto the problem.
VCDS is a must with these cars.
Code: “thermostat for mapped cooling j265 open circuit”
This means that my whole assembly (water pump + thermostat) is maybe bad, but the only code is with the thermostat. I live in Europe and this summer was very hot and nice. It didn’t overheat and didn’t seem to get any problems and I didn’t care about that problem. Now when it’s almost October and we are getting -0C, the car won’t get hot to 90C.
I see that I can only change the thermostat also, but is it a good choice? Should I change the whole assembly? I will be doing it DIY and make pictures all the way. I’ve got myself ELSA also and it’s good to have.
The thermostat code should be 079121115BA (https://bit.ly/2Ih65nC).
Heater exchanger core has some problems too now.
Code: “Coolant circulation pump v50”.
Found a guide that you can clean it. Why would you clean it, you may ask? That part is much more expensive that water pump and thermostat assembly. I’m getting warm/hot air inside my cabin, so I don’t know why that code is throwing up.
Has anyone opened up their car? What should I do? Replace only thermostat? Do I need to disassembel all my front? How to refill coolant without the pump etc?
