Audi S8 5.2L V10 engine problem
Hello iam new to the forum
My car is a 2007 it has lost almost all the power exsaust gases coming out from the left side ( LHD ) right side very little exsaust coming out the car drives like crap
So far I have changed the ECM relay and the fuel pump relay and all the spark plugs.
I have scanned it with Ross tech vcda and this are the results I get
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 28 34 36 37
38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: Mileage: 228830km-142188miles
03-ABS Brakes – Status: Malfunction 0010
05-Acc/Start Auth. – Status: Malfunction 0010
06-Seat Mem. Pass – Status: OK 0000
07-Control Head – Status: OK 0000
09-Cent. Elect. – Status: Malfunction 0010
15-Airbags – Status: OK 0000
1D-Driver Ident. – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
28-HVAC, Rear – Status: OK 0000
34-Level Control – Status: OK 0000
38-Roof Electronics – Status: Malfunction 0010
42-Door Elect, Driver – Status: Malfunction 0010
47-Sound System – Status: Malfunction 0010
4F-Centr. Electr. II – Status: Malfunction 0010
52-Door Elect, Pass. – Status: Malfunction 0010
53-Parking Brake – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: Malfunction 0010
57-TV Tuner – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
62-Door, Rear Left – Status: Malfunction 0010
65-Tire Pressure – Status: OK 0000
6C-Back-up Cam. – Status: Malfunction 0010
72-Door, Rear Right – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 B HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0050
Revision: 5AH11— Serial number: AUX3Z0F6300355
Coding: 01060000190F0160
Shop #: WSC 04418 001 1048576
VCID: 211CEF363DCB8DAF02D-8074
10 Faults Found:
000802 - Engine Speed Sensor (G28)
P0322 - 008 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:38:16
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.922 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 235
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:43:15
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 12.700 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 234
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:02:15
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.430 V
012312 - Valve for Exhaust Flap 1 (N321)
P3018 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 236
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 12.700 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 239
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 229
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 16
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 1107 /min
Load: 0.0 %
Speed: 8.0 km/h
Temperature: 33.0°C
Temperature: 28.0°C
Voltage: 13.081 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228839 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:34
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 28.0°C
Voltage: 11.430 V
Readiness: 0110 1101
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01— Serial number: 0089699
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2B000D1E4F0757FFA81-807E
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001927
Shop #: WSC 15792 000 00000
VCID: 2412E62222D9988769B-8070
2 Faults Found:
01314 - Engine Control Module
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F6300355
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58EA82D22E110C67353-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:04
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:48
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:00
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 E HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 300GI067570056
Coding: 0000002
Shop #: WSC 00020 767 88971
VCID: 2E06040A7C1522D78FF-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000016108
Subsystem 3 - Serial number: 0119.07.060000000100010147ÿ
Subsystem 4 - Serial number: 010147ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000102896
Coding: 0041465
VCID: 1C62DEC21AA9A047D1B-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133111
Shop #: WSC 99900 715 21581
VCID: 36362C6A84451A17C7F-8062
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000037
Shop #: WSC 99900
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 99900
4 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 245
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
12 Faults Found:
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 008 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:38:13
Freeze Frame:
RPM: 1436 /min
Load: 62.7 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 10.414 V
012848 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
P3230 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 190
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:46:31
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 23.0°C
Temperature: 26.0°C
Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.430 V
012322 - Valve for Exhaust Flap 2 (N322)
P3022 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 244
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:59
Freeze Frame:
RPM: 1339 /min
Load: 48.2 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.049 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 32
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:59
Freeze Frame:
RPM: 894 /min
Load: 41.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 28.0°C
Voltage: 11.684 V
008199 - Intake Manifold Flap; Bank 2
P2007 - 008 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:02
Freeze Frame:
RPM: 1019 /min
Load: 40.8 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.303 V
P2007 - 001 - Stuck Closed - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:02
Freeze Frame:
RPM: 1571 /min
Load: 77.6 %
Speed: 11.0 km/h
Temperature: 27.0°C
Temperature: 26.0°C
Voltage: 12.827 V
012869 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3245 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 87
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:37
Freeze Frame:
RPM: 2562 /min
Load: 32.9 %
Speed: 53.0 km/h
Temperature: 69.0°C
Temperature: 24.0°C
Voltage: 13.462 V
012800 - Oxygen (Lambda) Sensor B3 S1; Heating Circuit
P3200 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 176
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:52
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
012821 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
P3215 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 72
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 09:00:33
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P000NJ2-
Coding: 0431707
VCID: 2708F12E53EF739F4C9-8072
Subsystem 1 - Serial number: 63328RB401698380D
Subsystem 2 - Serial number: 63428RB4016983C4M
Subsystem 3 - Serial number: 63528RB401698389O
Subsystem 4 - Serial number: 63628RB401698398P
Subsystem 5 - Serial number: 63729RB4016630D3F
Subsystem 6 - Serial number: 63829RB40166317CK
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: 6594BB266963A18FBE5-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 D HW: 4E0 920 901 D
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F7000103
Coding: 0048613
Shop #: WSC 00070 000 00000
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0672280E2
Coding: F5F5DFFF50761E
VCID: 6C82CE028A8990C7E1B-8038
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E1 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 02082006105323
Shop #: WSC 00000 000 00000
VCID: 1F18E9CE0BBFBB5F349-804A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:21:46
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8162768
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000044278
Coding: 0000000
VCID: 619CAF367D4BCDAF42D-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 50656 001 1048576
VCID: 2A0E081A40FD4EF7537-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063854
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 364GW067580617
Shop #: WSC 74500 745 89398
VCID: 3B203D5EBF67C77F381-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000618800041
Coding: 0003286
VCID: 1D64D3C601B3A94F265-8048
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 180
Mileage: 228824 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032621
VCID: 201AEA3236C184A70D3-8074
3 Faults Found:
02128 - Door Closing Control Module (J657)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040607270177
Coding: 0012904
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 140
Mileage: 123608 km
Time Indication: 0
Date: 2012.08.22
Time: 08:58:49
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 114
Reset counter: 140
Mileage: 228584 km
Time Indication: 0
Date: 2016.12.11
Time: 19:44:38
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 C HW: 4E0 035 466
Component: BO_D3 H06 0310
Revision: 12S00002 Serial number: 01807060004248
Coding: 0000026
VCID: 2616FC2A54E56A9777F-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 02607060002092
Subsystem 3 - Serial number: 0226.07.060000000100030001ÿ
Subsystem 4 - Serial number: 030001ÿ
1 Fault Found:
03016 - Motor for Front Right Treble Speaker (V345)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 228839 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:35
Freeze Frame:
Voltage: 11.60 V
Temperature: 40.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 45.0°C
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000001477
Coding: 0010101
VCID: 1E66D4CA0CB5B2573FF-804A
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228836 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228836 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032621
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000731
5 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.49 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.39 V
Count: 41
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.39 V
Count: 243
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 228824 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:46
Freeze Frame:
Voltage: 11.59 V
Count: 61
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 9.83 V
Count: 24
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 00767 003 88971
VCID: 290CF71645FB45EF5AD-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396G$067543980
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:17:06
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146 C
Component: TV analog TUNER H15 0300
Revision: 00000053 Serial number: 00000000043427
Coding: 0000001
VCID: 2514FB2629E3618F7E5-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000014755
Shop #: WSC 00020 767 81772
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 33090441BM
Coding: 34453039313531303541205641303333303930343431424D
Shop #: WSC 50357 001 1048576
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:12:01
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:11
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:21
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:31:55
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:32:05
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032621
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:04
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:04
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700046741
Coding: 0212225
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000607210108
Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J66112A
Coding: 1021302
VCID: 5CE29EC25A29E04711B-8008
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:51
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032621
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.27
Time: 21:26:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:06
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720620900189
Coding: 0321008
Shop #: WSC 74500 745 89414
VCID: 2310E53E27D79FBF101-8076
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000008 Serial number: T2AUDX0806JNQX
Coding: 0000004
VCID: 221EE03A38CD96B71B7-8076
End----------(Elapsed Time: 02:19, VBatt start/end: 11.7V/11.7V)-----------
What could be the problem ?.
Thanks in advance
First off welcome to the forum.
The good news is your on the right forum and you will get all the help you need
the bad news is your car is in bad bad shape from the codes you posted. Did you get into a flood siuation or was there rain that got into the motor bay or water.
Did all these issues start at once after rain or was the car running fine and one day it just started running bad.
Its very helpful that you posted the vag com readout. Now that you have pasted that information here go back and clear all of the codes… there is an option in vag com for that. Clear all of the codes and then go back in and copy all of the codes that came right back. After that take the car for a spin for a few miles if you can then pull the codes and post those. That will tell us the bigger part of the story and we can tell you more of what issues your looking at.
The reason I suggested doing the above is from the looks of the codes the car is not in great shape but if you go through the steps I listed above we will be able to tell you more.
How old is the battery? Try changing it with a known good one or put a booster on it and see what kinds of codes come up. I had a ton of quessient current codes before changing mybattery even though it was only 3 years old…
First code, engine speed sensor…fauly crank sensor will have a huge impact on everything. Some cars wont even fire/run very poorly with a bad crank angle sensor…
Thank you Greg5OH and justincredible for your reply.
I bought the car roughly two months ago, the car run like a dream no issue’s except a faulty low beam bulb light (on the right side of the car when sitting inside the car), whenever i switched on the lights there would be an alarm on the dash check right headlight bulb i would simply switch off then back on two or three times and the bulb would go on, and the dash alert would go away.
It was a normal day while at the red light signal i heard a loud bang from the engine the rave meter started going up and down and the car was shaking heavily i managed to make it home. I scanned the car i could see Multiple short to ground messages.
Greg5OH
The car was not in a flood however i do frequently wash it with a high pressure horse just the normal body wash, sometimes some water does get inside the rear left tail light assembly and i can see bubbles inside it when it dries up, i does sometimes bring up a check tail light alert on the dash.
justincredible
when i bought the car it had those cheap 100Amps battery since the car run fine i never thought of changing it.
but since you mentioned the battery i bought myself a new Audi Varta Battery 110 Amps i have done the battery coding aswell and will soon take the car out for a spine.
Latest Update:
I took the intake manifold out, thanks Paul F and CountVohn for your intake removal post. here is the link: http://audirevolution.net/forum/index.php?topic=3221.0 i am a beginner it took me five hours to remove it (Was taking my time and being very very careful, it was totally worth it :slight_smile: :slight_smile: :slight_smile:
Ones the manifold was out the intake valves had carbon build up will attach the pictures and videos shortly unfortunately i did find a broken piece of flap blocking the second intake cylinder hole on the left side while standing in front of the car, i carefully removed it with a long nose pliers and the valve closed instantly with force, i opened the manifold and all the flaps were broken so i removed all the flaps thus my manifold is currently flap free :D.the two intake manifold motors are connected i can initiate them using Ross tech vcds. I did not do carbon cleaning i was out of time i just carefully gently cleaned out some carbon (the much i could) using tissue paper.
I assembled everything back and i started the car and cleared the codes, and the car sounded louder but still same issues, shakes vigorously, rave meter goes up and down, goes off after afew minutes sometimes after afew seconds.
When i floor it (while its packed) i here loud explosion sounds from the engine its mostly coming from the right side of the engine (When seating inside the car) afterwords when i check the exhaust colour its black smoke and a heavy smell of fuel.
I drove it very little just like 50 meters around the parking block. here are the recent codes, I will drive the car today for a good long distance and scan and post again.
Just noticed that the Codes from : Engine II have reduced from initially being 12 faults to now only 6 Faults Found: :slight_smile: :slight_smile: :),
Here are the codes
Thursday,02,February,2017,14:45:15:09850
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.2.0 HEX-V2 CB: 0.4334.4
Data version: 20170131 DS267.1
www.Ross-Tech.com
VIN: WAUPN44XXXXXXXXXX License Plate:
Mileage: 228910km-142238mi Repair Order:
VIN: WAUPN44E77N006126 Mileage: 228910km-142238miles
1D-Driver Ident. – Status: OK 0000
34-Level Control – Status: Malfunction 0010
38-Roof Electronics – Status: OK 0000
56-Radio – Status: OK 0000
10 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:35
         Freeze Frame:
                RPM: 1009 /min
                Load: 60.8 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Absolute Pres.: 990.0 mbar
                Voltage: 11.557 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:52
         Freeze Frame:
                RPM: 1161 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:52
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 23.0°C
                Temperature: 25.0°C
                Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Voltage: 0.000 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:07:39
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 25.0°C
                Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1161 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1161 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1161 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:17:27
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 23.0°C
                Temperature: 25.0°C
                Voltage: 12.446 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:18:18
         Freeze Frame:
                RPM: 167 /min
                Load: 100.0 %
                Speed: 0.0 km/h
                Temperature: 31.0°C
                Temperature: 25.0°C
                Voltage: 10.287 V
Coding: 0000001
Coding: 0001927
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 180
Mileage: 228912 km
Time Indication: 0
Date: 2017.01.05
Time: 00:09:10
Coding: 4063840
Coding: 0000002
Coding: 0041465
Part No SW: 4E0 910 279 Q HW: 4E1 955 113 C
Coding: 0133111
Coding: 00000037
Shop #: WSC 99900
Coding: 00141886
Shop #: WSC 99900
4 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
6 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:14:05
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 26.0°C
                Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 72
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:30
         Freeze Frame:
                RPM: 1192 /min
                Load: 59.2 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 9.779 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1161 /min
                Load: 45.5 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.049 V
P1572 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1161 /min
                Load: 45.5 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:33
         Freeze Frame:
                RPM: 798 /min
                Load: 37.2 %
                Speed: 0.0 km/h
                Temperature: 22.0°C
                Temperature: 25.0°C
                Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:18:01
         Freeze Frame:
                RPM: 960 /min
                Load: 41.9 %
                Speed: 0.0 km/h
                Temperature: 29.0°C
                Temperature: 25.0°C
                Voltage: 12.827 V
Coding: 0431707
Coding: 0012141
Coding: 0048613
Coding: 0000000
Coding: 0015510
1 Fault Found:
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:13:45
Coding: 4063854
Coding: 0003286
Coding: 0032621
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Coding: 0012904
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 140
Mileage: 123608 km
Time Indication: 0
Date: 2012.08.22
Time: 08:58:49
Freeze Frame:
Fault Priority: 3
Fault Frequency: 142
Reset counter: 140
Mileage: 228584 km
Time Indication: 0
Date: 2016.12.11
Time: 19:44:38
Coding: 0000026
4 Faults Found:
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 140
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:14:27
         Freeze Frame:
                Voltage: 11.40 V
                Temperature: 33.0°C
                Bin. Bits: 00000011
                Voltage: 11.50 V
                Temperature: 39.0°C
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 140
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:19
         Freeze Frame:
                Voltage: 11.40 V
                Temperature: 32.0°C
                Bin. Bits: 00000100
                Voltage: 11.50 V
                Temperature: 37.0°C
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 140
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:19
         Freeze Frame:
                Voltage: 11.40 V
                Temperature: 33.0°C
                Bin. Bits: 00000100
                Voltage: 11.50 V
                Temperature: 37.0°C
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:20
         Freeze Frame:
                Voltage: 11.40 V
                Temperature: 33.0°C
                Bin. Bits: 00000100
                Voltage: 11.50 V
                Temperature: 37.0°C
Coding: 0010101
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:00
Coding: 0032621
2 Faults Found:
Freeze Frame:
Fault Statu
Did you change the battery? when the manifold was out , did you cheak for any leaks? I think the vacum diagram its on a stick under the hood on the s8 , Did you cheak the ecus? water or humity free?
Will look into your error later , hope you can resolve them and learn in the proses
Sorry for my english , its not my first lenguage.
Regards.
Thanks JPW12 I disconnected the battery and then I started working on the car ones I finished I removed the old battery and I inserted the new one. Yes I did a simple check around just to make sure I have connected every thing back correctly. When you say vacum diagram good point I will check again the car all round. The second ECU ( engine 2) is free of water and humidity on the scan it says no communication with control module ( ECM ) i already changed the relay and the fuse still the same error message remains. Here is a video of the car and its current engine soundhttp://cloud.tapatalk.com/s/589734dcce254/videocompress-027-VID_20170202_145250.mp4
Sorry Something is wrong with this video link I think it did not upload correctly. Let me try and upload it again 8)
Good news the video works you have to open the link using chrome browser then download the video it’s arround 12 MB and then open it using vlc player and it will work. Will upload it on YouTube aswell to make it easier for everyone 8)
Latest Scan after long drive what could be the problem,
Monday,06,February,2017,03:18:57:09850
www.Ross-Tech.com
VIN: WAUPN44EXXXXXXXXX License Plate:
Mileage: 228970km-142275mi Repair Order:
VIN: WAUPN44E77N006126 Mileage: 228970km-142275miles
65-Tire Pressure – Status: Malfunction 0010
Component: 5.2L V10/4V FSI 0050
10 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:35
         Freeze Frame:
                RPM: 1009 /min
                Load: 60.8 %
                Speed: 0.0 km/h
                Temperature: 22.0C
                Temperature: 25.0C
                Voltage: 11.557 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:52
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228906 km
Time Indication: 0
Date: 2017.01.04
Time: 13:10:52
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.573 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: -40.0C
                Temperature: -40.0C
                Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:07:39
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 21.0C
                Temperature: 25.0C
                Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.446 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.573 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.573 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:17:27
         Freeze Frame:
                RPM: 1222 /min
                Load: 60.0 %
                Speed: 7.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.573 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.01.08
Time: 12:50:41
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 84.0C
                Temperature: 21.0C
                Voltage: 12.065 V
Cannot be reached
Coding: 0001927
1 Fault Found:
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 180
Mileage: 228912 km
Time Indication: 0
Date: 2017.01.05
Time: 00:09:10
Coding: 4063840
Coding: 0000002
Coding: 0041465
Coding: 0133111
Coding: 00000037
Shop #: WSC 99900
Coding: 00141886
Shop #: WSC 99900
4 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
11 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:14:05
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 22.0C
                Temperature: 26.0C
                Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:30
         Freeze Frame:
                RPM: 1192 /min
                Load: 59.2 %
                Speed: 0.0 km/h
                Temperature: 22.0C
                Temperature: 25.0C
                Voltage: 9.779 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 955 /min
                Load: 32.5 %
                Speed: 0.0 km/h
                Temperature: 17.0C
                Temperature: 19.0C
                Voltage: 10.668 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 29
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:31
         Freeze Frame:
                RPM: 942 /min
                Load: 89.4 %
                Speed: 5.0 km/h
                Temperature: 18.0C
                Temperature: 18.0C
                Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:16:33
         Freeze Frame:
                RPM: 798 /min
                Load: 37.2 %
                Speed: 0.0 km/h
                Temperature: 22.0C
                Temperature: 25.0C
                Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:18:01
         Freeze Frame:
                RPM: 2466 /min
                Load: 55.7 %
                Speed: 17.0 km/h
                Temperature: 69.0C
                Temperature: 28.0C
                Voltage: 11.430 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:31:48
         Freeze Frame:
                RPM: 320 /min
                Load: 58.0 %
                Speed: 0.0 km/h
                Temperature: 42.0C
                Temperature: 27.0C
                Voltage: 10.795 V
P3200 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:51:43
         Freeze Frame:
                RPM: 1222 /min
                Load: 71.7 %
                Speed: 0.0 km/h
                Temperature: 46.0C
                Temperature: 28.0C
                Voltage: 12.827 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:52:40
         Freeze Frame:
                RPM: 2574 /min
                Load: 76.0 %
                Speed: 34.0 km/h
                Temperature: 48.0C
                Temperature: 27.0C
                Voltage: 12.446 V
P3215 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 175
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:53:58
         Freeze Frame:
                RPM: 2992 /min
                Load: 78.0 %
                Speed: 61.0 km/h
                Temperature: 57.0C
                Temperature: 27.0C
                Voltage: 12.954 V
P3245 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 158
Reset counter: 255
Mileage: 228916 km
Time Indication: 0
Date: 2017.01.05
Time: 00:53:58
         Freeze Frame:
                RPM: 2992 /min
                Load: 78.0 %
                Speed: 61.0 km/h
                Temperature: 57.0C
                Temperature: 27.0C
                Voltage: 12.954 V
Coding: 0431707
Component: Lenks䵬enmodul H14 0040
Coding: 0012141
Coding: 0048613
Coding: 0000000
Coding: 0015510
1 Fault Found:
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228921 km
Time Indication: 0
Date: 2017.01.08
Time: 11:38:32
Coding: 4063854
Coding: 0003286
Component: Trsteuer.FS BRM003 0100
Coding: 0032621
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Coding: 0012904
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 140
Mileage: 123608 km
Time Indication: 0
Date: 2012.08.22
Time: 08:58:49
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 140
Mileage: 228954 km
Time Indication: 0
Date: 2017.01.08
Time: 12:20:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 147
Reset counter: 140
Mileage: 228584 km
Time Indication: 0
Date: 2016.12.11
Time: 19:44:38
Coding: 0000026
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 140
Mileage: 228921 km
Time Indication: 0
Date: 2017.01.08
Time: 11:39:09
         Freeze Frame:
                Voltage: 11.30 V
                Temperature: 19.0C
                Bin. Bits: 00000011
                Voltage: 11.50 V
                Temperature: 26.0C
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 140
Mileage: 228921 km
Time Indication: 0
Date: 2017.01.08
Time: 11:40:11
         Freeze Frame:
                Voltage: 11.30 V
                Temperature: 18.0C
                Bin. Bits: 00000100
                Voltage: 11.50 V
                Temperature: 25.0C
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
&nbsp
sorry for not replying again I keep trying to keep up with the thread.
fist off I would stop driving the car as your going to do serious damage.
According to all the codes the car is in bad shape
you have a no comunication code a code from the crank trigger your ecu II seems like its not working properly or its failed. You have lots of codes on the bank 2 that include short to ground 02 codes for the main 02s that control fuel.
From the codes alone your car needs serious service and I would 100% stop driving the car. Where are you located.
here is what I would like to see you do. clear all of your codes and just key up the car. Show me the codes for just engine 1 and 2 I dont need to see any of the other modules at this time.
We need to sort though the codes before we go any further. Because at this point the codes tell us your crank trigger isnt working your 02s are not able to control fuel your fuel purge is open your intake flaps are stuck and your ecu is dropping comunication. As strong as these motors are if you keep this up youll drill a hole in one of your pistons.
Thanks Justincredible,
Iam a expatriate working in Dubai, i stopped using the car.
occasionally i do take the car round the block, just to keep the battery alive.
Here are Engine 1 & 2 codes after clearing all fault codes and just key up the car.
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:48:54
         Freeze Frame:
                RPM: 917 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 23.0°C
                Voltage: 11.684 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:57:32
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 24.0°C
                Temperature: 24.0°C
                Voltage: 11.557 V
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:48:50
         Freeze Frame:
                RPM: 1105 /min
                Load: 51.0 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 23.0°C
                Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:48:50
         Freeze Frame:
                RPM: 1105 /min
                Load: 51.0 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 23.0°C
                Voltage: 10.922 V
U0100 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:48:52
         Freeze Frame:
                RPM: 1043 /min
                Load: 41.2 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 23.0°C
                Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228978 km
Time Indication: 0
Date: 2017.02.06
Time: 19:48:53
         Freeze Frame:
                RPM: 960 /min
                Load: 47.4 %
                Speed: 0.0 km/h
                Temperature: 21.0°C
                Temperature: 23.0°C
                Voltage: 11.303 V
Many Thanks.
ok great work. This helps in giving me good information.
so here is what the codes show.
1 count for codes for a failed or not able to communication engine speed sensor.
and
10 counts for no communication with ECU
So at this point it looks like ECU 2 cant get a crank trigger signal from ECU 1 and cant find out where the ignition is suposed to be. This can be why you got 02 codes as the 02s are not getting a proper AFR signal per what they believe they should be seeing.
My thoughts on this are that ECU 2 has some issues. Either the ECU itself is bad or the wiring to ECU has some issues. Clearly ECU 2 works as its giving you codes. If ECU 2 was dead you wouldnt be able to retrieve any codes.
If ECU 2 is damaged that will give you 02 codes as well. The codes for exhaust flaps and motor mounts are something you would want to look into but they are not going to be the bigger part of these issues.
My main suggestion to you. look for wire harness issues with the ECU 2 make sure there are no breaks in the wire harness that would cause issues. ECU 2 is having communication issues and that needs to be solved. It can be due to a break in the wires or even a bad ECU
It might not be a bad idea to get a new ECU 2. But to do this you would have to contact JHM in the states as they can clone ECUs for you. They would need both ECUs to clone for you. I think you would just need to buy 1 ecu but you would need to ship both of them to JHM to clone.
If your getting a clone ECU from JHM make sure to get a engine speed sensor at the same time as that is one of the codes you got as well.
Its hard for me to tell you if there is some electronic bug somewhere in the car or if you really have this many parts that have failed. Assuming you didnt have some event that caused a massive electronic issue the steps I suggested would be my first route
The last thing to add is that you had 02 codes for bank 3 and 4 they were for sensor 1 thats your main sensor I believe you can get to bank 3 sensor 1 easy. I think your bank 4 sensor 1 requires you to pull the motor to change it. If your 02 wires are open and somehow ground out on eachother that can damage the ECU as well. But in this siuation I think there is a better possibily that the ECU 2 is damaged and that is causing the 02 codes. But again unless I was able to look over the car and check the ohm resistance on the wires I dont know.
Thankyou so much Justincredible,
Will check the wiring harness fully this weekend, if i find any cable breaks will repair and switch on and see what results i get, if the wiring is okay, then i will contact JHM and make the order for the ECU and engine speed sensor. will update on the progress thanks cheers.
Hey Sweet_Potato did you ever resolve this?
