Hello iam new to the forum
My car is a 2007 it has lost almost all the power exsaust gases coming out from the left side ( LHD ) right side very little exsaust coming out the car drives like crap
So far I have changed the ECM relay and the fuel pump relay and all the spark plugs.
I have scanned it with Ross tech vcda and this are the results I get
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 28 34 36 37
38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: Mileage: 228830km-142188miles
03-ABS Brakes – Status: Malfunction 0010
05-Acc/Start Auth. – Status: Malfunction 0010
06-Seat Mem. Pass – Status: OK 0000
07-Control Head – Status: OK 0000
09-Cent. Elect. – Status: Malfunction 0010
15-Airbags – Status: OK 0000
1D-Driver Ident. – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
28-HVAC, Rear – Status: OK 0000
34-Level Control – Status: OK 0000
38-Roof Electronics – Status: Malfunction 0010
42-Door Elect, Driver – Status: Malfunction 0010
47-Sound System – Status: Malfunction 0010
4F-Centr. Electr. II – Status: Malfunction 0010
52-Door Elect, Pass. – Status: Malfunction 0010
53-Parking Brake – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: Malfunction 0010
57-TV Tuner – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
62-Door, Rear Left – Status: Malfunction 0010
65-Tire Pressure – Status: OK 0000
6C-Back-up Cam. – Status: Malfunction 0010
72-Door, Rear Right – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 B HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0050
Revision: 5AH11— Serial number: AUX3Z0F6300355
Coding: 01060000190F0160
Shop #: WSC 04418 001 1048576
VCID: 211CEF363DCB8DAF02D-8074
10 Faults Found:
000802 - Engine Speed Sensor (G28)
P0322 - 008 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:38:16
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.922 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 235
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:43:15
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 12.700 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 234
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:02:15
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.430 V
012312 - Valve for Exhaust Flap 1 (N321)
P3018 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 236
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 12.700 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 239
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 229
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 814 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 13.335 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 16
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:41
Freeze Frame:
RPM: 1107 /min
Load: 0.0 %
Speed: 8.0 km/h
Temperature: 33.0°C
Temperature: 28.0°C
Voltage: 13.081 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228839 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:34
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 28.0°C
Voltage: 11.430 V
Readiness: 0110 1101
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01— Serial number: 0089699
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2B000D1E4F0757FFA81-807E
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001927
Shop #: WSC 15792 000 00000
VCID: 2412E62222D9988769B-8070
2 Faults Found:
01314 - Engine Control Module
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F6300355
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58EA82D22E110C67353-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:04
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:48
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:00
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 E HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 300GI067570056
Coding: 0000002
Shop #: WSC 00020 767 88971
VCID: 2E06040A7C1522D78FF-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000016108
Subsystem 3 - Serial number: 0119.07.060000000100010147ÿ
Subsystem 4 - Serial number: 010147ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000102896
Coding: 0041465
VCID: 1C62DEC21AA9A047D1B-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133111
Shop #: WSC 99900 715 21581
VCID: 36362C6A84451A17C7F-8062
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000037
Shop #: WSC 99900
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 99900
4 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 245
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Reset counter: 140
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:00:00
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:56
12 Faults Found:
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 008 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:38:13
Freeze Frame:
RPM: 1436 /min
Load: 62.7 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 10.414 V
012848 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
P3230 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 190
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:46:31
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 23.0°C
Temperature: 26.0°C
Voltage: 11.303 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:36
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.430 V
012322 - Valve for Exhaust Flap 2 (N322)
P3022 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 244
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:59
Freeze Frame:
RPM: 1339 /min
Load: 48.2 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.049 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 32
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:59
Freeze Frame:
RPM: 894 /min
Load: 41.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 28.0°C
Voltage: 11.684 V
008199 - Intake Manifold Flap; Bank 2
P2007 - 008 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:02
Freeze Frame:
RPM: 1019 /min
Load: 40.8 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 11.303 V
P2007 - 001 - Stuck Closed - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:02
Freeze Frame:
RPM: 1571 /min
Load: 77.6 %
Speed: 11.0 km/h
Temperature: 27.0°C
Temperature: 26.0°C
Voltage: 12.827 V
012869 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3245 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 87
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:37
Freeze Frame:
RPM: 2562 /min
Load: 32.9 %
Speed: 53.0 km/h
Temperature: 69.0°C
Temperature: 24.0°C
Voltage: 13.462 V
012800 - Oxygen (Lambda) Sensor B3 S1; Heating Circuit
P3200 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 176
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 08:59:52
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
012821 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
P3215 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 72
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 09:00:33
Freeze Frame:
RPM: 2493 /min
Load: 87.8 %
Speed: 32.0 km/h
Temperature: 68.0°C
Temperature: 26.0°C
Voltage: 12.319 V
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P000NJ2-
Coding: 0431707
VCID: 2708F12E53EF739F4C9-8072
Subsystem 1 - Serial number: 63328RB401698380D
Subsystem 2 - Serial number: 63428RB4016983C4M
Subsystem 3 - Serial number: 63528RB401698389O
Subsystem 4 - Serial number: 63628RB401698398P
Subsystem 5 - Serial number: 63729RB4016630D3F
Subsystem 6 - Serial number: 63829RB40166317CK
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: 6594BB266963A18FBE5-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 D HW: 4E0 920 901 D
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F7000103
Coding: 0048613
Shop #: WSC 00070 000 00000
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0672280E2
Coding: F5F5DFFF50761E
VCID: 6C82CE028A8990C7E1B-8038
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E1 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 02082006105323
Shop #: WSC 00000 000 00000
VCID: 1F18E9CE0BBFBB5F349-804A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:21:46
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8162768
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000044278
Coding: 0000000
VCID: 619CAF367D4BCDAF42D-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 50656 001 1048576
VCID: 2A0E081A40FD4EF7537-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063854
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 364GW067580617
Shop #: WSC 74500 745 89398
VCID: 3B203D5EBF67C77F381-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000618800041
Coding: 0003286
VCID: 1D64D3C601B3A94F265-8048
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 180
Mileage: 228824 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032621
VCID: 201AEA3236C184A70D3-8074
3 Faults Found:
02128 - Door Closing Control Module (J657)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:04:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040607270177
Coding: 0012904
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 140
Mileage: 123608 km
Time Indication: 0
Date: 2012.08.22
Time: 08:58:49
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 114
Reset counter: 140
Mileage: 228584 km
Time Indication: 0
Date: 2016.12.11
Time: 19:44:38
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 C HW: 4E0 035 466
Component: BO_D3 H06 0310
Revision: 12S00002 Serial number: 01807060004248
Coding: 0000026
VCID: 2616FC2A54E56A9777F-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 02607060002092
Subsystem 3 - Serial number: 0226.07.060000000100030001ÿ
Subsystem 4 - Serial number: 030001ÿ
1 Fault Found:
03016 - Motor for Front Right Treble Speaker (V345)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 228839 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:35
Freeze Frame:
Voltage: 11.60 V
Temperature: 40.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 45.0°C
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000001477
Coding: 0010101
VCID: 1E66D4CA0CB5B2573FF-804A
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228836 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 228836 km
Time Indication: 0
Date: 2016.12.28
Time: 17:06:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032621
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000731
5 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.49 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.39 V
Count: 41
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 11.39 V
Count: 243
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 228824 km
Time Indication: 0
Date: 2016.12.23
Time: 00:03:46
Freeze Frame:
Voltage: 11.59 V
Count: 61
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Voltage: 9.83 V
Count: 24
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 00767 003 88971
VCID: 290CF71645FB45EF5AD-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396G$067543980
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:17:06
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146 C
Component: TV analog TUNER H15 0300
Revision: 00000053 Serial number: 00000000043427
Coding: 0000001
VCID: 2514FB2629E3618F7E5-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000014755
Shop #: WSC 00020 767 81772
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 33090441BM
Coding: 34453039313531303541205641303333303930343431424D
Shop #: WSC 50357 001 1048576
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:12:01
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:11
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:15:21
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:31:55
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:32:05
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032621
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 0 km
Time Indication: 0
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:04
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:04
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700046741
Coding: 0212225
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000607210108
Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J66112A
Coding: 1021302
VCID: 5CE29EC25A29E04711B-8008
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 180
Mileage: 228826 km
Time Indication: 0
Date: 2016.12.23
Time: 00:16:51
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032621
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 01:01:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.27
Time: 21:26:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 180
Mileage: 228816 km
Time Indication: 0
Date: 2016.12.23
Time: 00:22:06
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720620900189
Coding: 0321008
Shop #: WSC 74500 745 89414
VCID: 2310E53E27D79FBF101-8076
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000008 Serial number: T2AUDX0806JNQX
Coding: 0000004
VCID: 221EE03A38CD96B71B7-8076
End----------(Elapsed Time: 02:19, VBatt start/end: 11.7V/11.7V)-----------
What could be the problem ?.
Thanks in advance
