Good News i swapped the engine my car is back on the road
It currently has following problems.
It starts with a lot of hesitation, especially on cold starts,
The car shakes alot and there is engine vibration
The gearbox is sometimes unstable its like there is a delay in pick up, and it raves higher before changing gears.
sometimes it feels risky to drive it in heavy traffic.
Overall the car feels heavy and slow (it feels like you have carried five people in the car and loaded the trunk to capacity with heavy equipment’s)
Things the garage has done, apart from donor engine install.
Swapped the spark plugs,
Swapped the ignition coils
Swapped the Low fuel pressure sensor
Swapped the battery
Swapped the injectors
The donor engine had very little carbon build up, so no carbon cleaning nesesary
Here are the main engine codes.
Sunday,14,May,2017,13:55:37:09850
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
Mileage: 229970km-142896mi Repair Order:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 B HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0050
Revision: 5AH11— Serial number: AUX3Z0F6300355
Coding: 01060000190F0160
Shop #: WSC 04418 001 1048576
VCID: 211CEF363DCB8DAF027-8074
9 Faults Found:
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 229958 km
Time Indication: 0
Date: 2017.05.14
Time: 08:29:01
Freeze Frame:
RPM: 634 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 65.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.827 V
001633 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0661 - 002 - Short to GND - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 229958 km
Time Indication: 0
Date: 2017.05.14
Time: 08:54:26
Freeze Frame:
RPM: 656 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 102.0°C
Temperature: 63.0°C
Voltage: 12.192 V
008196 - Intake Manifold Flap; Bank 1
P2004 - 002 - Stuck Open - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 229958 km
Time Indication: 0
Date: 2017.05.14
Time: 08:54:28
Freeze Frame:
RPM: 841 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 63.0°C
Voltage: 11.811 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 229960 km
Time Indication: 0
Date: 2017.05.14
Time: 00:00:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 103.0°C
Temperature: 65.0°C
Voltage: 12.065 V
008198 - Intake Manifold Flap; Bank 1
P2006 - 008 - Stuck Closed
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229960 km
Time Indication: 0
Date: 2017.05.14
Time: 00:00:24
Freeze Frame:
RPM: 895 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 63.0°C
Voltage: 11.684 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 229960 km
Time Indication: 0
Date: 2017.05.14
Time: 00:01:24
Freeze Frame:
RPM: 645 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 65.0°C
Voltage: 12.827 V
008756 - Oxygen (Lambda) Sensor B2 S1
P2234 - 004 - Signal Shorted to Heater Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 229966 km
Time Indication: 0
Date: 2017.05.14
Time: 00:16:50
Freeze Frame:
RPM: 678 /min
Load: 56.1 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 65.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.446 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229971 km
Time Indication: 0
Date: 2017.05.14
Time: 04:29:07
Freeze Frame:
RPM: 140 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 74.0°C
Voltage: 10.160 V
Readiness: 0000 1101
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01— Serial number: 0089699
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2B000D1E4F0757FFA8B-807E
1 Fault Found:
013093 - Power Supply Terminal 15
P3325 - 000 - Implausible
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 229854 km
Time Indication: 0
Date: 2017.05.13
Time: 10:06:21
Freeze Frame:
RPM: 640 /min
RPM: 608 /min
RPM: 0 /min
(no units): 30.0
(no units): 22.0
Temperature: 93.0°C
T.B. Angle: 0.0°
7 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 229958 km
Time Indication: 0
Date: 2017.05.14
Time: 08:29:01
Freeze Frame:
RPM: 634 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 65.0°C
Voltage: 12.700 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 229960 km
Time Indication: 0
Date: 2017.05.14
Time: 00:00:19
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 65.0°C
Voltage: 12.065 V
P0300 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229966 km
Time Indication: 0
Date: 2017.05.14
Time: 03:25:08
Freeze Frame:
RPM: 615 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 49.0°C
Voltage: 12.065 V
000784 - Cylinder 10
P0310 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229966 km
Time Indication: 0
Date: 2017.05.14
Time: 03:25:08
Freeze Frame:
RPM: 615 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 49.0°C
Voltage: 12.065 V
000777 - Cylinder 9
P0309 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229966 km
Time Indication: 0
Date: 2017.05.14
Time: 03:25:08
Freeze Frame:
RPM: 615 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 49.0°C
Voltage: 12.065 V
012872 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3248 - 008 - Electrical Malfunction
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 229972 km
Time Indication: 0
Date: 2017.05.14
Time: 13:50:26
Freeze Frame:
RPM: 1759 /min
Load: 17.2 %
Speed: 64.0 km/h
Temperature: 91.0°C
Temperature: 67.0°C
Voltage: 11.430 V
00047 - Right Headlight Washer Jet Motor (V249)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 229896 km
Time Indication: 0
Date: 2017.05.13
Time: 21:15:00
All Help is appreciated
Thanks.
