Audi sport diff....no longer functions
Anyone have this happen to them? I am taking it back to the dealer but curious if anyone has encountered this. It says “stability control fault” when I do a code scan via carista. It no longer vectors torque. I just tried now with esc fully off and no dice. Sad face. Fwiw there is no leaking dff fluid, and no constant error light on the dash. But the diff definitely doesn’t vector torque anymore. It’s fully open all of the time
Wonder if it’s something else like a wheel speed sensor. Would be better if you could grab a vcds scan. That is the only dtc on the bus?
How would you know by VCDS scan…? Whenever I run a scan it gives me the same code as above “stability control fault” but nothing else.
You also have this code? Was just curious if there were other codes. But sounds like it’s just that one. ABS module?
No idea drop… Thought it was just some glitch… Need to need to investigate deeper… Read something g to that respect once but can’t remember exactly… Old age dam it… Hahaha
There should be more codes that went with it. Is it an electronic actuated diff right. If you can post the full code that might tell us more. That is odd tho. As these cars start to get older it looks like we will be finding more and more of these bugs. What year is your car
Just did an auto scan and it showed up again. I copied and saved will post it.
I also did a little blast thru second but stupid me touched a button on computer and lost that log lol. Wanted to see CPS cooling efficiency and if any to I g got pulled but it’s not to be… DA’s here tonight in the 1800’s and humid…perfect conditions…
My car is a 2015.
FWIW some genius dumped coolant all over the track and didn’t pull off immediately, so i did spin out on some coolant and have an off. But not sure this would affect anything.
https://www.youtube.com/watch?v=4OMvfQ2AJ3A
That sucks. It’s one of the most dangerous situations I think you can get into in a typical HPDE. One of the reasons I like running with Audi club is 90% of attendees have a car that is less than 5 years old. The last 3 times coolant has been dropped it has been some e36 or e46 BMW, hand wrenched by some moron who’s too good to get help.
Ok let’s see if I can post the scan on here…
Sent from Windows Mail
Monday,31,August,2015,22:36:57:04409
VCDS – Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: License Plate: STEVES4
Mileage: 35390km-21990mi Repair Order:
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
62 6C 72 A9
VIN: Mileage: 35390km-21990miles
04-Steering Angle – Status: OK 0000
09-Cent. Elect. – Status: Malfunction 0010
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
22-AWD – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
47-Sound System – Status: Malfunction 0010
56-Radio – Status: OK 0000
5F-Information Electr. – Status: OK 0000
A9-Struct. Borne Sound – Status: Cannot be reached 1100
Address 01: Engine (J623-CGXC) Labels: 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07—
Coding: 0A250034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 383CE27B8342B2E196F-806D
2 Faults Found:
8900 - Coolant Pump for Intercooler
P190D 00 [040] - Mechanical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 35233 km
Date: 2015.08.26
Time: 14:10:04
6143 - Fan 2 Control Circuit
P0693 00 [045] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 35233 km
Date: 2015.08.26
Time: 14:09:00
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H02 0009
Revision: --H02—
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 40CC8A9BDB92FA212EF-8015
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 291D1A
VCID: 0444468B870A26014A7-8051
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 0D814000000000000000
VCID: 014A4F9F98183329611-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01200420130516
Coding: 6600228000
VCID: 393AE77FB048ABE9691-806C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000046375002
Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000030100000030000000
VCID: 78BC227BCBC272E156F-802D
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 020413 H07 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
3 Faults Found:
02258 - Door Opener Transmitter
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 35233 km
Time Indication: 0
Date: 2015.08.26
Time: 14:09:24
01496 - Bulb for Fog-Lamps; Left (L22)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 42
Mileage: 35233 km
Time Indication: 0
Date: 2015.08.26
Time: 14:10:58
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 42
Mileage: 35233 km
Time Indication: 0
Date: 2015.08.26
Time: 14:10:58
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H45 0610
Serial number: 003KJD91NWC3
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 53951 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4AD8A8B3EDAE3071F0B-801F
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R130000DAW9
Crash sensor for side airbag; driver side:
Serial number: 6334MSME783246306
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME7A705A17L
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME5B302746F
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME5B2D094E-
Crash sensor for front airbag; driver side:
Serial number: 63732SME2D2F28705
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME2D2F23420
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130423000290
Coding: 000036
VCID: 51EABFDF08F803A9B11-8004
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 L HW: 8K0 920 982 L
Component: KOMBIINSTR. H35 0556
Revision: 00400000 Serial number: UVU64F94E
Coding: 8BB709008301D705020000
VCID: 3D32F36FA46097C9459-8068
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y134140111
Coding: 80C303FF00
VCID: 4AD8A8B3E5AE3071F0B-801F
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
1 Fault Found:
03619 - Control Module for Structural Accoustics
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 29860 km
Time Indication: 0
Date: 2015.04.21
Time: 12:49:26
        Freeze Frame:
               Bin. Bits:    11111
               Voltage: 13.10 V
               Count: 6
               Bin. Bits:    00000
               Time: 4.90 s
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 000704130001414
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F2ED927760C7559C75-807A
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000057114738
Coding: 00581B00000000000000
VCID: 3B36FD77BA7499F97BD-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56E04CC321166491643-8003
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0014398095
Coding: 100000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 3424D64B9F2A5681BA7-8061
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0305247425
Coding: 0106023A00FA400580B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813013657002
VCID: 2D12C32F74000749F59-8078
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
        Freeze Frame:
               Voltage: 12.50 V
               Temperature: 47.0°C
               Temperature: 49.0°C
               Bin. Bits: 00000100
               Bin. Bits: 00001000
               Bin. Bits: 00000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55E24BCF3C106F896D9-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 30000000041841
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
6 Faults Found:
334080 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
329728 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Freeze Frame:
329984 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Freeze Frame:
331264 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Freeze Frame:
331520 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Freeze Frame:
331776 - Function Restricted due to Missing Message(s)
U1111 00 [000] - -
Freeze Frame:
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156D-0D7717108
Coding: 020007010000000001
VCID: 220820133DDEC83158B-8077
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 204DU0D7574008
Coding: 110200000206A1EF45028B4E00000403140000000000000000
VCID: 373EE147865CBD999F5-8062
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C13204000210001
VCID: 59FA47FF50084BE9491-800C
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07— Serial number: 525PA8-J3190QC
Coding: 1000006
VCID: 383CE27B4B42B2E196F-806D
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 0304
Address A9: Struct. Borne Sound
Cannot be reached
End-------------------------(Elapsed Time: 02:46)--------------------------
It seems I found more then I’d like but will post to CPS tread also and see what comes of it…thought it might help with the Diff problem…
Damn close call, you were pretty close to that guy in front of you :o. Corners workers immediately black flag it?
No corner workers on this track lol. It was a horrible track day. They also let him continue on for another full lap before flagging him. Smh. Anyway I am at the dealer now. Update: they scanned it and found no faults or codes. Carista interestingly makes my dash board show “stability control fault” whenit does diagnostics…but the dealer cannot reproduce this. They also say no issue with diff. I will just drive harder and determine if that’s true :D. I wonder how long the clutch packs last in the diff?
The “stability control fault” popping up momentarily during the scan is normal (VCDS or Carista, or whatever…). It does that when it scans that module.
Oh lol that makes sense then. Anyway, since Audi reset my ecu, the diff vectors again. Car rotates a lot on the throttle. All is well! Thanks all for your input
Its common for that and for when you scan the ABS module.
Did the ECU reflash fix it
