I got a fair bit done today.
I started with removing the pedal box, clutch lines and master cylinder from the Akoya Silver car. I’ve done a couple of manual swaps on B6 A4’s, both were LHD, one was a 1.8T, the other a 1.9TDI.
One thing worthy of note - the procedure is totally different between LHD and RHD cars. It took me about an hour, mainly due to not having the tool the disconnect the brake pedal from the brake booster’s pushrod. I installed it in the Denim Blue car, using the grommets from the donor car. Having a complete car makes all the difference.
I also removed the cable from the ignition lock to the tip shifter.
While the clutch fell fine, the throw-out bearing was really noisy, so I installed a new clutch kit. The clutch pressure plate and friction disk looked fine, when I pulled the transmission from the engine. The throw-out bearing was completely shot. Noisy, and rough in operation. The plastic ring was so worn, it fell off. It was ridged, and the pressure plate had actually worn right through. All buttoned up, tomorrow I’ll shove the engine and transmission into the bay.
The transmission…being an '03, means no 01E 6-speed here. It’s got the later 02X 6-speed, which is nowhere as robust as the Getrag 01E. The 02X has a torque limit of 330 Nm, which a stock 4.2 V8 already exceeds. I have an 01E, from a B5 2.5 TDI, which will be bolted behind a built 4.2 V8 40V turbo, come next summer.
Pictures!
http://i768.photobucket.com/albums/xx329/NaijaGuy/Audi%20B6%20420-S/IMG_0246_zps8hge260r.jpg
http://i768.photobucket.com/albums/xx329/NaijaGuy/Audi%20B6%20420-S/IMG_0281_zpsb0xytono.jpg
3-pedals installed:
http://i768.photobucket.com/albums/xx329/NaijaGuy/Audi%20B6%20420-S/IMG_0280_zps2fiapl7n.jpg
Clutch hard line installed:
http://i768.photobucket.com/albums/xx329/NaijaGuy/Audi%20B6%20420-S/IMG_0279_zps4wilpm0z.jpg
Clutch master cylinder feed line:
http://i768.photobucket.com/albums/xx329/NaijaGuy/Audi%20B6%20420-S/IMG_0278_zpseljyq9t0.jpg
