B6/B7 Fastener Tightening Specs
Wheels
Audi models except RS 2 and RS 4 (type 8D) 120 Nm
RS 2 130 Nm
RS 4 (type 8D) 140 Nm
RS 4 (type 8E) 120 Nm
Q7 160 Nm
PAX wheels 140 Nm
A 6 (security) 140 Nm
A 8 (security) 140 Nm
Gears, Shafts
Dual Mass Flywheel
Dual-mass flywheel to crankshaft
Bolt length
22.5 mm 60 + 90 ° 1) 2)
35.0 mm 60 + 180 ° 1) 3)
43.0 mm 60 + 180 ° 1) 3)
Sealing plugs in cylinder block 25
  1. Replace bolts.
  2. 90 ° corresponds to a one quarter turn.
  3. 180 ° corresponds to a one half turn.
Thanks for the info MDUBZ. I have some Front Suspension torque specs to add along with a component chart and some notes. I figured it would be best to add these here since there’s already a thread. Let me know if you want me to make my own.
http://i.imgur.com/xXq5QEk.png
1 - Bolt, 75 Nm
2 - Washer
3 - Bolt
40 Nm
Always replace if removed.
4 - Upper link, rear
5 - Bolt, 7 Nm
For adjusting track constants “S”
6 - Bolt
7 - Nut, self-locking, 45 Nm
8 - Bolt, 40 Nm
9 - Nut, self-locking
10 - Upper link, front
11 - Strut
12 - Bolt, 70 Nm + an additional 180 degree turn.
13 - Lower guide link
If hydro bushing leaks, it must be replaced, refer to
Lower Guide Link Bushings .
14 - Nut, self-locking, 110 Nm
15 - Wheel bearing housing
On vehicles with a headlight range control module, note sensor removal and
installation.
80 Nm + 90°
16 - Drive axle bolt
M14 115 Nm
M16 200 Nm
Place vehicle on ground then + 180°
17 - Bolt, 10 Nm
18 - Shield plate
19 - Nut, self-locking
20 - Bolt 90 Nm
21 - Subframe support
22 - Bolt, 55 Nm
23 - Bolt
110 Nm + an additional 90 degrees ( 1 / 4 turn).
The threads in the body can be repaired according to DIN 8140 using wire thread
inserts (Heli-Coil). The thread insert must be the same length as the threads in the
body.
24 - Bolt
40 Nm + an additional 90 degrees ( 1 / 4 turn).
25 - Connecting link
26 - Bolt
27 - Lower control link
28 - Bolt 70 Nm + an additional 180 degrees turn.
29 - Bolt, 75 Nm
inserts (Heli-Coil). Thread insert must be the same length as the thread in the body.
30 - Subframe
31 - Nut, self-locking
32 - Nut, self-locking
33 - Multi point socket head bolt
First pre-tighten all bolts to 15 Nm, then tighten all bolts to specifications.
Tightening specifications:
M8 bolt: 40 Nm
M10 bolt: 70 Nm
34 - Backing plate
35 - Drive axle
Removing and installing, refer to
Drive Axle .
36 - Bolt
40 Nm
37 - Nut, self-locking
50 Nm + an additional 90 degrees ( 1 / 4 turn).
38 - Nut
50 Nm
