Brakes - Hydraulics Components
Ball Head to Brake Booster 30
Front Brake Caliper, C54
Brake carrier to wheel bearing housing 190 Nm
Brake caliper to brake carrier 30 Nm
Front Brake Caliper, FN3
Front Brake Caliper, FNR-G 60
Bleeder valve to brake caliper 10 Nm
Bleeder valve to brake caliper 15 Nm
Hydraulic unit with bracket to longitudinal member (Bosch 8.0) 10 Nm
ABS sensors to wheel bearing housing 10 Nm
Splash plates to wheel bearing housing 10 Nm
Front Brake Caliper, Brembo
Brake caliper to brake carrier 110 Nm
Brake carrier to stub axle carrier 190 Nm
Brake lines to brake hoses 15 Nm
Brake pads to wheel bearing housing 10 Nm
Rear Brake Caliper, C38
Brake hose to brake caliper (banjo union with banjo bolt) 38 Nm
Brake caliper to brake carrier 35 Nm
Brake carrier to wheel bearing housing 75 Nm
Rear Brake Caliper, C41 and C43
