Being a b6/7 s4 (A6 and allroad guys to) owner you only really have two major worries. 1 is the timng components and 2 is the scored cylinder walls that come from a warped block or uneven piston expansion. What we have found out over the years is that the precats hold in way too much heat and some of that heat makes it way back into the cylinders causing uneven expansion of the piston or worse the warping of the block. The good news here is you can help reduce motor issues by removing the precat. Even if it’s too late and you already have a damaged block the removal of the precat will stop it from being worse and in some cases help reduce the amount of oil consumption.
The b6/7 s4 has the precat right at the exit point of the exhaust manifold. The precat is within 4 inches of the cylinder exhaust port. Not only is this terrible for power it’s a huge hindering to the long term health of the motor. To give you an idea on just how close the precat is here is a picture of the precat with the red arrow. The blue arrow is the exhaust manifold
http://audirevolution.net/addons/albums/images/948991046.jpg
If you go back just before 2001 there was no use of precats. A federal law passed in the late 90s required new cold start emissions laws. For the first few years after this law was passed company’s put the precats right up on top of the exhaust manifold just like the S4. Since then most car manufacturers have moved the precat further back away from the exhaust manifold giving the motors a better chance at breathing. A combination of that and better cat technology have removed most of the issues that are occurring with the S4.
For those of you who are never going to modify your car or worry about the possibility of pollution. You still should remove your precats. Stock cars are still effected with scored cylinder walls and warped blocks due to the issues with the precats. Even if you remove the precat there is still the main cats in place. The main cats are more then enough to keep the air clean. As a matter of fact no car with the precats removed that is still using the main cats has ever failed emissions due to the main cat not being able to handle the emissions load.
In this picture you can see what the main cat looks like.
http://audirevolution.net/addons/albums/images/283023169.jpg
The main cats are actually very good and can stand the test of even the highest requirements of emissions standards
Now that you can see just how close the precat is and just how harmful it is you can see why removal is a good idea. Even if your stock. In the end removing the cat helps keep your motor happy and adds a few more hp. It’s a us do can’t go wrong mod
