B6 S4 Overheating after reinstall
To give some background info, I replaced my 04 S4 engine with an engine out of an 08 S4 Cabriolet. I have everything back together and running, but I can’t seem to figure out why the car keeps overheating. When I run the heater, it gets hot as the car gets up to temperature. But once up to temp (12’ O’clock) and the radiator fans kick on, the air gets cold and the temp needle starts to creep up until the overheat warning comes on. At this point there are bubbles non stop in the expansion tank for several minutes, sometimes coolant comes out of the bottom of the tank. There is clicking which sounds like it is coming from the cap.
I pulled the top heater core line and let the coolant come out of the bleeder hole, but I can’t figure this out. I even replaced the thermostat thinking it may be stuck closed (which was a nightmare with that spring!!), but no change.
I triple checked all of the lines to the top of the engine so i’m pretty confident they are all on correctly. The only other issue I’m getting is a loud, almost whistling sound at all RPM’s. I think I have it narrowed down to a bad PCV valve.
Any thoughts or similar experiences? Thanks!
