q_dubz, the first thing you do is come in here and call us NAIVE…that is pretty hilarious considering this is the most technically knowledgable Audi forum on the internet. Now if you said, “why are you guys always so skeptical?” that would be a great observation.
We also aren’t going to take your word that these European courses are accurate.
[quote=q_dubz]All thanks to tuning.
I’ve also seen you make this comment before, sure great tuning is necessary, but you can’t tune around the weak limits of HARDWARE. It’s a balance between the proper hardware setup and tuning brings it all together. To run times like these the car has to be making pretty good power, way better than the stock motor can handle…regardless of the tune.
I feel like you’re a smart guy but you’re gullible. You make assumptions that certain things are simple. Last time we spoke about built motors… over two years ago…and you said you had everything sourced (pistons, rings, rods, a machinist). How is your build and testing coming? I also found it funny that you said the most expensive part was the timing components, but in my mind that is the easiest and least expensive part of the equation. JHM has been doing the R&D and changing their processes for the last few years on their built motor so I hardly believe any part of a BHF build can be handled in ONE SHOT. Anyways if you do go through with an attempted build keep us posted.
