I have been trying to get a couple dimensions off a B7 flywheel for a few days over on Audizine but not having any luck. Could one of you guys that has a B7 flywheel (aftermarket or OEM Dual mass) laying around please measure 2 things?
The step height from the friction surface to the pressure plate mounting surface. Should be 3/8" but I need confirmation.
The overall height from the crank mounting surface to the pressure plate mounting surface (i.e. set it on a table and measure the distance from the pressure plate mounting surface to your table).
I’m trying to machine my Clutchmasters B6 flywheel to accept a B7 RS4 pressure plate and I need it by Wednesday. :o Huge thanks to anyone that can help.
