Just out of curiosity, try the following logging for the misfires. The recommendations by the other smart(er) guys in this thread come first of course.
Log block 3 with one or more of blocks 15, 16, 17.
Or use Advanced Measuring blocks and check off all block 3 measurements and the misfire counter measurements in blocks 15-17. So 8 misfire counter measurements and 4 measurements from block 3. This way is preferable since you get all the info in one logging session.
You’ll need to go through the second ecu controller (“Engine-II” controller under the drivetrain tab IIRC) to get the misfire blocks to populate.
Log the following use cases:
Idle
Light throttle (cruising style, 0-18%) holding at various RPMS (2k, 3k, 4k) while driving in various gears.
heavier throttle accelerating
Just curious to see which cylinders are misfiring and under what conditions (Since those codes aren’t in your original post)
