Time to update, at long last manage to sort the gremlins with the vFiz system and my sensors out so I am now totally satisfied with the placement of the sensors and the readings. The temps have been verified with an external meter and readings correspond with the temps from the vFiz which confirms that the firmware and internal calibrations are correct.
For reference I am just going to re-post my Sensor names as displayed on the DIS by the vFiz system. Also added the Boost sensor which I now have connected.
Explanation of the short display names so that it make sense.
KCT - In-line sensor reading of coolant between the Chiller and Intercooler.
RVCT - Sensor reading of reservoir coolant
IMAT - Air intake Sensor Post Intercooler
IAT - The OEM intake reading from the MAF sensor before the blower, so that’s underhood intake temps
BST - Boost reading from the Intake Manifold
In the previous pics of the temp readings all readings were skewed except for the RVCT(Reservoir Water) sensor. I also mentioned at the time that Mario from Qmatis was in the process of shipping over a new system to me which I now have installed in the car.
Before I post some pics just an update on the changes I made and the work rounds to fix the things I weren’t satisfied with.
Firstly, the new vFiz fixed the skewed reading from the in-line temp sensor between the Chiller and the Intercooler. Common sense suggested that it should read a few degrees cooler than the Reservoir sensor, which it didn’t >:( The Thermocouple manufacturer wasn’t concerned as it was within parameters but it irritated the hell out of me ??? Anyway, all good now as can be seen from the pics below.
Secondly, as mentioned before, in my haste to get all the sensors installed I placed the sensor for the IATs after the Intercooler just behind the throttlebody :
Bad placement, as explained before the Throttlebody butterfly diverted air flow away from the sensor probe so those reading were way off. Moved that sensor to the intake silicone hose between the Intercooler and Manifold and the results speak for itself ;D
Last but not least, fortunately I never hooked up a Boost sensor when I did the initial install so I could now use the vacant tapped hole in the manifold, that use to house the IAT sensor, for my boost pickup. Got a suitale NPT boost nipple and hooked that up to the vFiz boost sensor.
Display of DIS with new vFiz - In Garage
http://audirevolution.net/addons/albums/images/651823013.png
On the Road
http://audirevolution.net/addons/albums/images/468783362.png
http://audirevolution.net/addons/albums/images/810412014.png
http://audirevolution.net/addons/albums/images/969718136.png
Ok, so what’s outstanding? The current system still run “Dual Zone” only, meaning both the Chiller and the Cabin is getting cooled down. As per Jimmy’s writeup I ran into the same problem when switching the Drag Valve to bypass the cabin to enable Single Zone. As intended the cabin does get bypassed but the the Chiller temps also started rising instead of getting colder. The solution is to install another Solenoid on the High Side of the AC system anywhere before the orifice tube. Jimmy explained that in his writeup as well so that’s something I still need to do.
As things would have it though, the long overdue Solenoid eventually got deliverred today from Joe @Kincaid so I need to find the time and energy to pull the bumper again to get that installed. Will report back again once that’s done. Based on Jimmy’s tests I do expect the temps to go down even lower due to all the AC coolant being directed toward the Chiller.
But, as things stand I am pretty satisfied with the results of the system, definitely a must do mod for any boosted car with a separate Air to Water intercooler setup.
